DC coupling
Hellhammer
DC coupling
Trying to figure out how to choose Ra and Rk for a dc coupled ECC82 stage. If I have 130V on the grid, 300V HT and want to bias it cold, lets say at -8V, how do I go about designing this stage? I've been trying to draw load lines for different values of Ra+Rk, but it just won't add up. I'm missing something. Cheers.
/Stewart
Hellhammer
Re: DC coupling
OK I think I figured it out. If I approach it from a different angle it makes sense. I have 170Va-k at my disposal so I start by drawing load lines from this point.
If i pick 15k for the anode resistor and want the cathode at 138V i read the -8 grid and 15k(blue) anode lines crossing at 1.5mA.
The cathode resistor should be:
138/0.0015=92k.
82k is a close enough standard value. I can now draw a load line for Ra+Rk=97k(pink)
Drawing a cathode load line for 82k(orange) shows that bias will be close to -8V.
Drew load lines for 10k anode and 68k cathode resistors as well.
Is this correct?
138/0.0015=92k.
Is this correct?
/Stewart
Re: DC coupling
You need to draw a tube chart for a CF. (The grid voltage lines should be virtually vertical. See Merlin Blencowe's 1st book Ch 5.)
For a DC-coupled pair using a 12AU7 with an HT of 300V, I would use say 22k 2W (keeping both 1st-Ra and CF-Rk the same) and bias the inverting stg for around 6-7V. You probably also need to elevate the heaters to around 50V.
Re: DC coupling
Actually, in Merlin's book, this exact scenario is in Chapter Two.
Hellhammer
Re: DC coupling
I'm not trying to do a CF.
Yes I've read that part of chapter two in Merlins great book a hundred times but I'm still not sure how to bias it cold so I reach cutoff way before grid current limiting. I didn't do it right I guess?
/Stewart
Re: DC coupling
Sorry I see now. Do you want the second stage for an inverter (since you haven't included a bypass cap for that 2nd Rk?)?
You could try level shifting (i.e.: still DC-coupled).
Hellhammer
Re: DC coupling
I left the bypass caps out just for clarity. Just a normal gain stage... or not so much gain as distortion!
I might have to do some levelshifting to get the signal down as well. I just want to get the theory to make sense first. So are my calculations off?
/Stewart
Re: DC coupling
I think Merlin's approach is a bit trial and error: start with a minimum Rk value based on estimated current; pick a value for Ra; then draw your DC load line as you have done. Then draw the cathode load line and see if it crosses where you want. If not, change values. I can't remember if programs like TubeCAD do this for you, but that would be easier.
Re: DC coupling
The bigger the divider in the level shift, then the more gain you will be able to get out of the second stage (because you will be able to use a lower Rk and get the plate to cathode voltage in V2 bigger). However as the level shift increases (i.e.; the more voltage dropped at the voltage divider output), then the more likely you will have to bypass the upper leg of the voltage divider with a cap to keep the high frequencies. So its really about picking a bias point for the V2 stage and then making the level shift output about 6-8V lower than that (for a 12AU7).
Hellhammer
Re: DC coupling
I appreciate your replies guys, I really do! But one question is still unanswered. Are my calculations wrong?
I drew bigger lines just for clarity.
/Stewart
Re: DC coupling
It seems legit as far as I can see, but I'm a little confused by your initial assumptions -- that you want the tube to hard clip from cut-off versus soft clip from grid current limiting. Why not just use a transistor
If you really need -8V bias point, it forces the large Rk, and in turn a fairly small Ra. So to get reasonable gain, you'll need a really big cathode bypass cap. Even then, I think gain is only about 11 (which may be fine for your purposes).
Hellhammer
Re: DC coupling
Thank you! I'll have gain stages enough for plenty gain. I'm not sure if I want cutoff or grid current limiting but I'm gonna experiment with both and maybe have the bias point switchable in the end.
/Stewart
