Vibrolux Reverb
Vibrolux Reverb
Anyone know if the re-issue Vibrolux reverb amps ( 10 years old ) are point to point or PCB.
Re: Vibrolux Reverb
I've worked on a re-issue Twin, and a re-issue Deluxe Reverb and both were PCB. I'm assuming the Vibrolux is as well.
<i> "I've suffered for my music. Now it's your turn."</i>
Re: Vibrolux Reverb
Worked on a couple of RI Vibrolux Reverbs over the last few years for warranty service, they were both PCB.
Re: Vibrolux Reverb
PCB
- Shotty wave soldering. I've had a half dozen on the bench that needed the board to be resoldered. I even had one that had an octal socket that was never soldered. Just holding on by pressure. Really dissapointing build quality IMHO.
My Daughter Build Stone Henge
Re: Vibrolux Reverb
If you are talking about the Custom Vibrolux reverb, they have dual pots wired in parallel. But they still crap out regularly. I always replace them with standard single CTS pots. at least the pots are not directly soldered to the pcb.
Re: Vibrolux Reverb
I think he's talking about the Brown one.
Re: Vibrolux Reverb
I've had a few dozen Reissue fender PCB with that issue cross the bench.
easy fix.
test the tubes if you can replace them with know good tubes.
if they test good and the noise is still a problem.
open up the amp
make it safe to work on.
resolder every point and connection in the amp. I'm not joking!
make sure every nut and bolt is snug tight, even on the iron.
close it up .. good as new.
easy fix.
open up the amp
nicely done
Thanks for that heads up.
A
A
