PT Outer Limits
PT Outer Limits
Hello, I have a 150ma--275v Hammond PT, Would I be pushing it too hard to run a quad of EL84-GZ34-and three 12ax7? Thank you.
Re: PT Outer Limits
Do you know what the heater winding is rated at?
That is the determining factor.
4 x EL84 = 3 A
3 x 12ax7 = 1 A
So 4 amps heater current.
4 x EL84 = 3 A
3 x 12ax7 = 1 A
Re: PT Outer Limits
Thanks Structo, mine is only 3A. I love that avatar.
- David Root
Re: PT Outer Limits
Modern Hammond transformers are VERY conservatively rated.
Which model do you have?
Typically they can handle 30% higher than rated on the HV winding, if they are the same on the 6V3 winding you are still probably OK.
Re: PT Outer Limits
I made a mistake on the specs. The 5vt is 3A and the 6.3vt is 5A. It is a Hammond 270FX. Thanks!
Re: PT Outer Limits
I was going to say that usually the 6.3v tap is rated pretty high with 6 amps being typical for many PT's.
Re: PT Outer Limits
Is the 150ma. high enough for the 3-12ax7 and 4-el84? Thanks again.
- David Root
Re: PT Outer Limits
I would think so.
