Dumble 183 BOM
Garveyte01
Dumble 183 BOM
Hi everyone, I searched the 183 files but haven’t found a BOM for this amp. Does anyone have a list of parts I would need I would greatly appreciate it! Thank you
Re: Dumble 183 BOM
I have a couple different BOM files, hopefully this one is correct
- ijedouglas
Re: Dumble 183 BOM
This BOM is not even remotely close. I'm not sure where to even start.....
You would do a whole lot better by taking the component types and values off the layout (https://ampgarage.com/forum/viewtopic.php?f=5&t=13095).
Ian
Re: Dumble 183 BOM
I'll second what Ian suggested, basically starting from scratch. Even if you find a BOM I strongly recommend verifying each component on it for accuracy to avoid possibly having to pause the build waiting for a missed or incorrect component to come in. This requires basically the same effort as starting from scratch... Plus I personally consider it part of the fun/challenge of doing a build.
Glenn
I solder better than I play.
