I recently went through a LTSpice bootcamp, of sorts, tracing and modeling the Two Rock John Mayer Signature as documented by Amplified Nation's Wonderland layout. I believe it's 95% accurate since I can run the simulation and the tone curves look right
I embarked on this endeavor after trying to learn about changes I can make in my clone of this awesome amplifier. I don't believe I've seen a Dumble circuits simulated in full using LTSpice (or at least available online) so I figured I'd post it here to forward the progress of understanding these circuits and making changes before physically making changes. If anything looks incorrect and you've made some changes, please do report them and I can commit the change on GitHub.
I'm hosting the downloads on GitHub for the sake of version control. When I make a update or change, GitHub makes it easy for us to monitor my change log and download "releases" if I make large improvements. I plan on adding a Steel String Singer LTSpice circuit soon too which will be on the same repository. Enjoy!
https://github.com/colganr/LTSpiceCircuits
-Ryan "The Tone Geek"
