Original SSS Chassis Design
I'm working on contracting out getting a few SSS #004 chassis mades and my question is, does anyone know the kind of chassis nuts used on the early SSS's? As well as distance measurements? Attaching a few pictures of what I made up so far and pics I'm using for reference. I was originally thinking it might be Fender's 5" spacing but the top pics of the original seem further apart.. AutoCAD work is my own and once I'm done I'll share all files. The preamp layout is a little bit different for what I want to build but for the forum I'll modify and upload the master "SSS top view" tube layout. Thanks in advance!
Ryan
https://www.thetonegeek.com/
AndrewCgolden
Re: Original SSS Chassis Design
Any chance you could share the autocad file with me?
- dorrisant
I have one of the SSS chassis that rj had made up when he was diving down the SSS rabbit hole. It is still blank and could be measured for any of the dimensions you need. If this is good enough, I have the source for measurements.
Sorry I am not sure about the mounting hardware. If you are interested, I'll post some pics of it later.
AndrewCgolden
I'm interested!!
