I'm looking for a good readable Turret layout (but also PCB if is a printable version) of the fet input of the #124
Many Thanks
K
I'm looking for a (Turret or PCB) layout of the fet input
- Kagliostro
Re: I'm looking for a (Turret or PCB) layout of the fet input
I can do that. What turretboard grid and size you want?
That would lay down nicely on VOX's style tagboard... just saying
Link me to that NTE's data sheet
K, just get one of Ceriatone's OTS layouts. They show an eyelet board layout you can use.
- Kagliostro
@ Turret
@ Martin Manning
is the attached turret board correct ?
If possible I would like to have also a printable version of the attached PCB, someone has one to share ?
Many Thanks
K
@ Martin Manning
Many Thanks
K
That's it. You will likely have to adjust the source resustor to bias the FET correctly, and also adjust the 8k2 in the 150k-8k2 voltage divider to get the Vd that you want.
- Kagliostro
Thanks Martin
K
K
