There are three or four layouts here for internal D'lators.
I hope I didn't come off snarky.
I pulled my layout to fix it.
Hopefully this will work.
I installed the bypass on my serial loop yesterday and it works great.
Not sure if I want to mod my D'lator to parallel or make a whole new loop.
The shielded cable noted on the layout is not official. I just included it to show that the longer runs should probably be shielded for best noise reduction.
Placement of the Series/ Parallel and Bypass switches should be given some consideration. I put my Bypass switch above the jacks for easy access. I may put the Series/ Parallel on the back as well. It will keep the front from getting too cluttered.
Wire colors are just to show contrast with each other and are not official.
