DUMBLE MASTER
mirlo02
DUMBLE MASTER
Post by mirlo02 »
HI,SORRY FOR MY ENGLISH,I HAVE ONE QUESTION,IN THE DUMBLE AMP THE MASTER ONLY WORK IN THE CLEAN CHANNEL? WHEN I LOOK AT THE FACEPLATE I SEE VOLUME,WORK ALL TIME,LEVEL AND RATIO,WORK IN OVERDRIVE CHANNEL,AND IN THE POWER AMP(E.X. 124) MASTER AND PRECENSE,BUT WHEN SEE IN THE SCHEMATIC THE MASTER CONTROL ONLY WORCK WHEN IS IN CLEAN CHANNEL,I AM CONFUSED,THE SCHEMATIC IS CLEAR,IN OVERDRIVE MOD MASTER IS OFF,BUT IN THE FRONT OF THE AMP,THE MASTER CONTROL SEEM WORK ALL TIME,I AM WRONG?THANKS
JimiB
Re: DUMBLE MASTER
Post by JimiB »
depends if its a bluesmaster or not.
glasman
Re: DUMBLE MASTER
Post by glasman »
It is a variable. But I think all amps that did not have the internal tone stack (HRM mod) have a Master that works in clean and overdrive.
Most later amps with internal HRM stack have separate masters. I say most as I played a 50W bluesmaster style that had a common master control.
About 5 miles south of I-94
www.glaswerks.com
