To start, I put the bias caps in with the negative leads to ground. Why was I only getting -5V? Why is my lightbulb limiter so bright? 2 hours later it dawned on me what I'd done, and I replaced the shorted caps with a new pair. Dilbert #1 solved.
Next why this terrible hum? Checked all grounds, moved some to various locations to check for lowest hum, still unusable. Grounding the gtid of V1B helps, PI input even more. WTF?
Put the scope on it, nope not 60Hz, it's 120Hz.. damn, no CT on the heaters. Put in the 100/100R's and powered it back up. Dilbert #2.
Now WHAT??? No noise at all, picked up the guitar and wow, it's working but 0 hum. It's so quiet I thought that there was no output at all.
Next step, move my test cab out of my room so I can bring in a real cab, test various tubes, this Funk chassis and board set is a work of art. This amp's got tone that'll deflower a virgin at 100 paces.
