Hi,
The stock D'Lite has nothing between the MV and the input of the PI. But I notice a lot of other versions of the Dumble amps have something...often a 100k resistor with a 47pF cap across it in series. What is this for?
Post MV R/C pairs
Re: Post MV R/C pairs
Of course the 15 pf is a bright cap for the master.
The only time I have seen the 100k is on the pre out on the loop.
Thats a high pass R/C filter. Fun to play with changing the R and the C to shape things. A good example of this filter is where HAD uses a 220k/500pf (or 220k/330pf on some schematics) to feed V1B, something that you never see in Fenders, but is essential to the Dumble tone.greiswig wrote:Hi,
www.RedPlateAmps.com
- RJ Guitars
George, have you tried this? I'm always up for a new tweak and was curious if this is something I need to do?
rj
rj
http://www.rjguitars.net
LooseChange
Although very popular in Marshalls (470k/470p)!heisthl wrote: Thats a high pass R/C filter. Fun to play with changing the R and the C to shape things. A good example of this filter is where HAD uses a 220k/500pf (or 220k/330pf on some schematics) to feed V1B, something that you never see in Fenders, but is essential to the Dumble tone.
That's not the same!LooseChange wrote:Although very popular in Marshalls (470k/470p)!
In Marshall's the 470K/470p is part of a (frequency dependent) voltage divider, in Dumble's the 220K/330p is a bypassed swamp resistor, to avoid the enhanced, by the swamp resistor caused high loss due to the tube's Miller capacity.
Larry
Larry's Website now with included Pix's Gallery
