I have had a few nice amplifiers, including a Ceriatone OTS50 / OTS20 and a RedPlate Blackverb (the last was the nicest amplifier I ever had) but all of them were too loud in my little spare bedroom - even the 20 W job. And that’s despite the fact that (from my understanding) the power sections of these amplifiers are not designed to be driven hard.
So I found myself a practical and cheap way to get nice Fender blackface style cleans and Dumble overdrive - actually with a
1. Blackstar HT5 Mkii clean channel American voice (scooped blackface cleans) with a
2. Tubesteader Beekeeper directly into the FX return. Dumble mid-rich cleans and overdrive.
The Blackstar has a push-pull power section, using the two halves of the 12BH7.
The 10% powerscaling switch gives me only one reduced volume setting - but it works perfectly.
I previously used a Sennheiser e906 hanging in front of the cab - then changed to a SamSystems Integral mic (so much neater). That goes to a stereo effect processor (TC G-Natural) for stereo chorus, delay and reverb that goes to a pair of stereo full range speakers on either side of my 1x12 (a trick I learned from Larry Carlton) for modulation effects positioned at the very end of the signal chain after the speaker.
The speaker cab has a mild upward angulation which I accentuated by putting bigger feet at the front and smaller feet at the back. I use it open back.
The whole set-up switches on with one power switch and is a lot nicer than plugging into an interface/computer - even though S-Gear does sound lovely.
I’m guessing that since the Beekeeper is a separate unit, it doesn’t allow me that whole negative feedback NFB function but I don’t really know how that works anyway…
My apologies. I don’t know how to post photographs from my mobile phone. Will try again later when I get home.
Dumble sounds at home-friendly volume
Re: Dumble sounds at home-friendly volume
The Beekeeper is the D preamp, and that section is outside of the global feedback loop in the D topology. Same as it is in your setup.
That's correct - here is a pic of the BeeKeeper
Thank you Martin.martin manning wrote: ↑Thu Sep 18, 2025 12:07 pmThe Beekeeper is the D preamp, and that section is outside of the global feedback loop in the D topology. Same as it is in your setup.
Would you please explain what might be the benefit of using:
A Dumble clone (such as Ceriatone LunchBox OTS Mini / OTS 20)
vs
My separate Dumble preamp (BeeKeeper) into the FX return of my Blackstar HT5 (power amp)?
Dumble power amps are clean, so as long as you are running your Beekeeper into a clean power amp there shouldn't be much difference.
