Dumble SSS with Eyelet Boards
desertmouth90
2 others liked this
I have aquired two sets of Hoffman eyelet boards of his Steel String Slinger set but just looking at the layout and in some places it looks different... for example I have to drill out the holes for the valve sockets clearance.
I am intending to use some 70s Fender Twin transformers for the build (Hopefully have enough mA for each valves, not sure how to test for this yet but im working on it.)
So far ive collecting parts for it. Not sure wether to go for parts close to the originals for more contemporary ones.
The Chassis is made from aluminium, I intend to get a silkscreen instead of a faceplate. not sure where to go in the UK for this but push comes to shove ill get faceplates custom made.
Any advice before I go down this particular rabbit hole?
Re: Dumble SSS with Eyelet Boards
Silkscreening a single chassis would not make economic sense. I'd go with laser engraved faceplates.
Your Twin PT should have enough current, but it looks like it has been hot based on the varnish oozing out of it.
The Hoffman rectifier board does not have the bipolar power supply shown in the layout. I recommend replacing that.
BTW, who made that modified layout?
desertmouth90
My mistake, Ill be following this one more.
Okay I can do the faceplates. I have to cut the chassis myself
desertmouth90
Now I look silly, I just posted your layout!martin manning wrote: ↑Wed Aug 27, 2025 3:22 pm Silkscreening a single chassis would not make economic sense. I'd go with laser engraved faceplates.
Not sure who edited it, But ill be following your original layout.
thanks,
Clive
Colgan did the original version. I would go with the edited one you posted. It has the modifications I have suggested on this forum (bipolar driver supply, bias pot connection, and revised step filters). I would replace the 300mH inductor with a jumper, though. It has no significant effect in the audio range.
desertmouth90
Yeah I think ive heard about this inductor not doing much from a friend who built this with Erwins PCBs.martin manning wrote: ↑Wed Aug 27, 2025 4:14 pm Colgan did the original version. I would go with the edited one you posted. It has the modifications I have suggested on this forum (bipolar driver supply, bias pot connection, and revised step filters). I would replace the 300mH inductor with a jumper, though. It has no significant effect in the audio range.
I was going to aquire those but it out of my budget slightly at the time.
Does the Bias pot need to be B25k?
Don't waste your money.desertmouth90 wrote: ↑Thu Aug 28, 2025 1:21 pm Yeah I think ive heard about this inductor not doing much from a friend who built this with Erwins PCBs.
No. See the bipolar bias supply .pdf document here: https://ampgarage.com/forum/viewtopic.p ... 08#p365408
Assuming you're following my layout since your boards match, you can do B25k or B20K. I use the 2W wire wound in my build for additional degree of accuracy and a little beefier than a standard carbon. It was my way to take a fixed bias and make it variable without changing too much and will fall back to fixed bias if the pot fails instead of red plating the tubes. If you're going with Martin's suggestion of a bipolar bias supply, follow that layout and disregard my suggestions
Ryan
https://www.thetonegeek.com/
desertmouth90
Straight from the horses mouth! Both of you have helped me get into this hobby the most out of everyone haha.rccolgan wrote: ↑Thu Aug 28, 2025 8:24 pm Assuming you're following my layout since your boards match, you can do B25k or B20K. I use the 2W wire wound in my build for additional degree of accuracy and a little beefier than a standard carbon. It was my way to take a fixed bias and make it variable without changing too much and will fall back to fixed bias if the pot fails instead of red plating the tubes. If you're going with Martin's suggestion of a bipolar bias supply, follow that layout and disregard my suggestions![]()
I might try both ways. I have to retrofit an old evil twin that I’ve gutted. Needs to be a proper amp again!
I merely scratch the surface compared to Martin's contributions.
Looking forward to your progress!
Ryan
3 others liked this
Don't sell yourself short- Sorting out the SSS002 circuit was epic!
desertmouth90
desertmouth90
Marking out the chassis ready for drilling!
desertmouth90
First mockup! Almost got the chassis ready!
Not sure I can get faceplates sorted in the U.K. for it, also would be a shame to cover this nice aluminium finish don’t you think?
Any ideas on getting a vinyl or waterslide or something?
desertmouth90
Progress!
