First post here - I am in awe of the knowledge and generosity here, and a little apprehensive to ask my questions as I am very much a newbie to the dark arts of amplifier building.
I have converted a Fender 75 amplifier to a circuit that closely follows the JM Wonderland amplifier. I have use as much of the original amp as possible, but used the typical TW/AN/Ceriatone layout. Everything worked out great so far, I'm just in the first trials with my test 12" cab. The original cab has a 15" speaker, which I will put the chassis back into for final testing.
My question is about the reverb circuit in this. I can see it mostly follows the AB763 scheme with some smaller values for the cathode bypass caps. The Fender 75, although not great in several aspects, did have fantastic reverb - on 10 it was cavernous!. The new circuit needs both the send and return pots on 10 to get anything like an average depth.
I am going back through the build, testing every component again to ensure there are no wrong values, but if that proves fruitless, I'm wondering what would be good places to start adjusting the circuit for a deeper effect. Is it the mixing resistors?
My working schematic is included below. Many thanks in advance.
