Anybody using 6P3S tubes in D-style amps?
Raoul Duke
Post by Raoul Duke »
I’ve found mixed “search” results regarding their ability to handle plate voltages above 400 and the internet seems to have a half dozen data sheets floating around that vary quite a bit - so thought I’d get a consensus amongst other HAD-type builders with more experience.
Any info/insight is appreciated!
Thanks!
Marc
Marc
bepone
Re: Anybody using 6P3S tubes in D-style amps?
Post by bepone »
me,
on 400-420vdc you can use -E version, 6P3S-E,
Raoul Duke
Thanks, that seems to be the consensus of all the info I'm seeing.
Marc
