My chassis from Amplfied Nation has a hole for an impedance selector, I would like to put one in. How would I wire this?
Thanks in advance, Brian
What is the speaker output impedence on the #124? Or is this picture missing the impedence selector?
- ijedouglas
Re: What is the speaker output impedence on the #124? Or is this picture missing the impedence selector?
4 Ohms - Twin Reverb OT. I just plug the hole if using an old Schumacher transformer
Ian
Here is a pic of my AN chassis with the selector switch and how I wired it. I have an Edcor OT so the wire colors may not match yours but hopefully this will help.
Connect the switch common to the tip connections of the speaker jacks. The OT common to the jack shields. The 4, 8 and 16 ohm OT wires to the appropriate selector switch input.
Glenn
I solder better than I play.
E34L? How does that sound with an 124?
Edit, and on topic: your wiring makes sense and looks correct. You verified 16 Ohm selects the lug where the 16 Ohm transformer lead is going?
For safety you could use a switched jack as main speaker output. Connect the switch contact to ground and the OT always sees a low impedance when accidentally nothing is connected. I also always wire the ground lugs of the output jacks to a ground point. That way there is always a ground point even if the jacks become loose. Not that I ever had that happening, but better safe than sorry.
Edit 2: I already see you have the switching jack. Genuine big facepalm on my side.
This is actually my 183 based build, but I wired the impedance selector the same as my 124 build. The 183 happened to be out of its cabinet so I took pics of it.
I triple checked the appropriate wires and lugs are matched up which means they really should be right
They are switched jacks but now that you mention it I need to double check that I grounded the main switched lug.
Glenn
