My second Dumble type build. Huge THANK YOU to everyone that has made the layout and schematic freely available here on TAG.
AN Silver chassis
Edcor Iron
3x Noval
4x EL34
Alpha pots
3 footswitchable relays-PAB, FET and OD.
20 AWG solid conductor PVC jacketed wire
Following 183 values shown on current layout by Tony Albany. https://ampgarage.com/forum/viewtopic.php?f=5&t=13095
Current production NTE MF where indicated and CF from Jelle. Caps as noted on layout, all current production.
Not sure why pics are upside down
I really hope their website is correct because I got quite a few...
I just sent an email inquiring about this to NTE's customer service, I'll post here any response I receive.
I am pretty sure, but please let us know what you find. I spoke with several vendors trying to track down any MF they may still have in stock over the summer. A couple confirmed that NTE phased out MF, the shiny blue type you see in many Dumbles and replaced them with MO the dull greyish type you have.
dbharris wrote: ↑Tue Dec 19, 2023 8:45 pm
-Dan
I also sent an inquiry to nteinc.com tech assist. Their datasheet just says "METAL" on the top, not specifying Film or Oxide. Now I'm not so sure they are MF like I was before. Regardless I'm going to see how they sound. If I don't like them I've got a full set of CF from Jelle I can put in with current production Dale RN and CMF MF for plates and cats.
Yes I'll definitely post any replies I get from NTE, but might be some time with the Holidays....
metal oxide and metal film are all FILM, correct name for metal oxide is metal oxide film..
i think that NTE is MOX blue and gray version the same, only old/new, but to be sure must be destroyed and compare the resistance track inside between those NTE and regular MOX resistor....i never did because i find NTE so rarely in this part of the planet
jelle wrote: ↑Wed Dec 20, 2023 11:29 pm
Be careful with this here, the resistor will short once the conformal coating gives out. I would move it away from the nut. jelle
