Question on the Precision power board?
Dragon1
Post by Dragon1 »
DIY_Eyelet_Boards_100W_ODS_r2.pdf
New guy question>>>
On this Precision power board are we replacing the four laydown 22uf's F+T's with eight standup 47uf 315V or are we adding them to the board???
Thank you, Brian
Dragon1
Re: Question on the Precision power board?
Post by Dragon1 »
Well that didn't work, wanted to insert the pic.
Again thanks, Brian
rccolgan
Post by rccolgan »
I believe it's a choice of one or the other. The 47uf is effective ~23.5uf 630v (series capacitance) https://www.khanacademy.org/science/phy ... ors-series
I'm not the most versed in ODS circuits but I believe that's correct. (Team, correct me if I'm wrong here)
Ryan
https://www.thetonegeek.com/
Dragon1 wrote: Fri Oct 13, 2023 10:35 pmOn this Precision power board are we replacing the four laydown 22uf's F+T's with eight standup 47uf 315V or are we adding them to the board???
The Precision PS replaces each of the 4 axial caps with a pair of radial caps and the necessary balance resistors. Per the notes, you need to add four eyelets to the axial cap board.
Dragon1
Post by Dragon1 »
Thanks for clearing it up .
Brian
