I'm finally getting to building a #102. I was gifted the chassis, and board (an AA Electronics board) by professormudd
I also got a batch of components from Smitty that I'm using everywhere I can. I bought the OT and a choke from a forum member a while back, and I've got some other components like caps for precision power supply, etc.
I do have a question, I've seen a lot of the detail on this, and am still a bit confused. It seems that #102 was built one way, and then sent back and had the HRM done to it later? I have the layout that was posted here:
https://ampgarage.com/forum/viewtopic.php?f=5&t=12873
But I took a schematic from the same thread that seems to be a bit different (subtle stuff like the od second stage showing a 1uF cap instead of 5 like the layout etc,) Is there a specific schematic I should use that mirrors the layout there? I've built a HRM version when I did the 183, but I seem to recall someone somewhere saying the updated version with HRM was preferred? Or am I mixing up amps here?
Either way, thanks to professormudd and smitty for the donations, and finally I'm getting to building it.
I'll need to buy a few more components I'm sure but I figured I'd put it all together as much as I can first to see what's missing
~Phil
