Add HT fuse to Dumble
Bombacaototal
Re: Add HT fuse to Dumble
HT fuse should be 1A for 100W amp. I had 0.5A on my SSS 002 and caused a lot of issues
- pompeiisneaks
- Site Admin
I don't think you're supposed to add a CT to a Bridge Rectifier like that. It's bad news. You should add the HT fuse inline between the rectifier diodes and the Standby switch, or after the switch, I'm not sure if the inrush current there will be a problem or not, though.
~Phil
~Phil
tUber Nerd!
Phil, I don't see a bridge, it's a two-phase rectifier.
See here for discussion on fusing the HT: http://www.valvewizard.co.uk/fuses.html
In addition to not protecting the transformer against shorted rectifier diodes, fusing the CT on a transformer with a bias tap will damage the caps in the bias circuit if the fuse opens.
- pompeiisneaks
- Site Admin
Oh I do that a lot... sorry, I see multiple diodes more than a single per side I let my brain melt and forget that you need a 0 ref for it to be a bridge. This is just extra diodes in case one fails short.
Sorry nothing to see here, move along lol
~Phil
~Phil
tUber Nerd!
timrobertson100
In addition… Since you have 240V on that diagram you may be in the UK. If so, I believe your power switch should be a double pole and also switch the neutral. Perhaps someone could confirm that?
frusciante89
fred.violleau
Looks good to me!
Fred.
Fred.
