This topic picks up where I left off in 'ODS 124 - revisited for the 21C'
https://ampgarage.com/forum/viewtopic.p ... &start=360
The prior topic was focused on the possibilities for updating and refining the ODS124 amp to include reverb and a few extras. Where it was exploratory, this topic will include the build, testing and final project files.
To get us started, I include my working schematic: SKYLINER 2.0
[Edit; updated 18/12/2021 to SKYLINER 2.1 - observed voltages added]
A note about the PSU: When working inside the amp, I always ensure my caps are drained before starting any procedure. Resistors in parallel with the caps in the PSU naturally discharge all the caps when the amp is switched off (but still plugged in) to a safe working level within about 2 minutes.
And also, my layout: SKYLINER, low plate custom reverb
Please note that the SKYLINER 2.0 schematic is largely untested. The only tests I can confirm at the moment are that the relay system works and that the FET has been biased using two 9V batteries in series. As I write, the amp circuit has not yet been powered up and I'm following the discussion on forming new electrolytic caps before I proceed with further testing.
A word about the structure of the layout pdf. I was very impressed by user coolidge's '#183 build attempt' topic: https://ampgarage.com/forum/viewtopic.p ... 26#p423326 and noted especially that he had built his amp in layers. This is true of the #124, too. We can see it in the photos hosted on Rob Livesey's site https://thesubjectmatter.com/dumblearchive.html and so, when constructing the pdf it was done in layers with the first stages at the bottom and the final stages at the top. This provided the blueprint for the build. When you open the pdf, you will see all the appropriate build layers on top of one another. Use adobe acrobat (or reader) to hide the layers to 'Hardware base, back and side panels' which was my start point, integrating the components with the chassis.
Some layers are you start and finish before moving to the next and others (later on) are combined to include a bit of this and a bit of that. And I already have some notes about what works and what doesn't work so well but following this layout pdf, you have a kind of build manual for how you might put this amp together yourself.
I've tried to keep the build as faithful to to Dumble's methods as possible and so at the very first layer, you will find the layout made from the files in https://ampgarage.com/forum/viewtopic.php?t=5719 - Ayan Gill, Martin Manning, Tony Albany, ic-racer, "Billy" all deserve special mention and my profound thanks for their historical contribution to the #124 documentation and study. The photos and sketches became my primary source, backed up by the 1.6 (1988) layout [correction: the schematic is 1.6 and another vital point of reference, but the layout by Tony and Martin was my main go to]. If you compare the original photos with my build, you will see there are many similarities, but some differences as well, this is an updated and modified version, after all.
When it came to the reverb, I owe a special debt of gratitude to Baz for his study and Spice simulations of the #060 reverb circuit which is incorporated in this build. Frustratingly, Chris Barnett, who documented the #060 with schematic sketches and photos didn't offer much for the reverb part of the circuit so we used Aaron's schematic of the #060 and the photos, and Baz's simulation to piece it all together. As it stands, you will find some components are coloured red as a memo to self to test these components for their values but if I were to include all the supposed values for completeness, the whole reverb circuit would be in red perhaps. However, the testing to be performed will be to reduce the -6dB loss Baz simulated and that will probably hone in on the mixing and grid resistors as outlined in my previous post by Martin Manning.
Baz, if you're listening, I have the components for the other reverb circuits you put together but they deserve whole new amps for testing
The pdf layout is largely illustrative, meaning that some views are made for clarity, as you will see from the photos I will be posting, in real life, the lead dress was slightly different. I do think lead dress is very important to the SNR and so I've done everything I can to be as faithful to the Maestro as possible.
Forgive the omission if I haven't mentioned you by name, I've listened and learned so much from you. Thank you.
Stephen
