Amp Porn
talbany
Amp Porn
Post by talbany »
I had to do some upgrades on 3 of my amps so I had them all out of the cabs at the same time so I thought I would take a quick shot and share it..Sorry about the quality all I have is my phone :roll:
Left to right....Low plate classic/Low plate Skyliner Music Man/High plate Skyliner (separate bias pots)
telentubes
Re: Amp Porn
Post by telentubes »
sweeet! immaculate construction.
Colossal
Re: Amp Porn
Post by Colossal »
Beautiful amps, Tony! Thanks for sharing them, and all the Dumbley information you contribute
talbany
Re: Amp Porn
Post by talbany »
Here are a few more of the Low Plate Classic..Really beginning to warm up to this amp :D
ijedouglas
Re: Amp Porn
Post by ijedouglas »
Very nice! Are those 1 watt Q-Lines on the OD out?
Ian
talbany
Re: Amp Porn
Post by talbany »
ijedouglas wrote: Sun Feb 21, 2021 12:49 am Very nice! Are those 1 watt Q-Lines on the OD out?
Yes although I believe Draloric listed them as 0.7 Watts under the 0617 Type..I am not sure if Sprague listed them as 1 watt on the package? The 100k's are 5% Tolerance and both have the yellow band IMO same resistor..:D W.German
ijedouglas
Re: Amp Porn
talbany wrote: Sun Feb 21, 2021 1:17 am
Yes although I believe Draloric listed them as 0.7 Watts under the 0617 Type..I am not sure if Sprague listed them as 1 watt on the package? The 100k's are 5% Tolerance and both have the yellow band :D W.German
I have the same ones. Sprague listed them as 1 watt on the package. How do they sound compared to the 1/2 watt?
Ian
talbany
Re: Amp Porn
Post by talbany »
ijedouglas wrote: Sun Feb 21, 2021 1:22 am
Hard to say right now? being as I only have 1 half watt in the amp and it's in the PI and I literally just installed it today the jury is still out but so far it sounds like a Q-line (thumpy) :D
Thanks!
dbharris
Re: Amp Porn
Post by dbharris »
Very nice Tony, thanks for sharing!
-Dan
Smitty
Re: Amp Porn
Post by Smitty »
Thanks for sharing, Tony. Lots of very cool parts. Here's a 124ish with a board on the side that I can change the tone stack values by paralleling caps. The little tines are soldered together to make the connection. I put a slope control in the FET hole.
Smitty
Re: Amp Porn
Post by Smitty »
carbon comps in low current positions
Smitty
Re: Amp Porn
Post by Smitty »
27k/2k2/.39uf feedback with a 10K pot. Mullard tropical fish.
Smitty
Re: Amp Porn
Post by Smitty »
390pf 630v BC film treble cap
Drive control on OD1 and trimpot on OD 2. I know the ratio I want between OD1 & 2, but adjust the input to OD1 based upon the gain of CL2. More better.
Smitty
Re: Amp Porn
Post by Smitty »
121k from B+5 to ground to simulate current drawn from FET. Sprague 516D cathode bypass.
Smitty
Re: Amp Porn
Post by Smitty »
I changed the lower end of the feedback resistor to 2k2 so I could use a 10K pot and .39uf topical fish
