Honestly though, this amp has played hundreds of gigs without fail and it sounds killer. Sometime around 2013 I switched over to a high plate configuration, added a deep switch (great on clean with a strat), and repaired the input jack that I had broken. Opening this thing up sent me down memory lane.
Back in 2009 I found you guys and started reading every post in Dumble Discussion/Files... I literally read through the whole thing... it wasn't as deep back then. I spent days on end staring at the Rob Livesey photos and comparing them to layouts
I am positive my family thought I was crazy when I disassembled and stripped out a perfectly good Fender Twin.
Since this build, over the years, amp building and repair became one of my main hobbies. This amp became just one of my backups, but it needed some TLC.
Anyway, no real point here. Thanks for a decade of knowledge and entertainment TAG. Here's my sloppy first build from 2010
