#124 sprague atom TVA 1628 replacement.
Thenewguy
Post by Thenewguy »
I'm just starting a #124 build and I can't find a replacement or a substitute for the Sprague Atom, TVA 1628 ,350V, 300µF capacitors. Does anyone here have a suggestion or a workaround for this?
norburybrook
Re: #124 sprague atom TVA 1628 replacement.
Post by norburybrook »
you can use 220uF's instead if you cant get 300's. F&T do a nice 220uF :D
or get radial caps and make some different holes on your power board.
M
Thenewguy
Post by Thenewguy »
Thanks for the suggestion. I have been thinking about using the 220's by f&t, I've seen them used on other amp builds. I wasn't too sure how crucial it was to stick with the 300's. This is most likely what I will do. I just needed someone to confirm. Are there any other changes that need to be made or are they a direct swap?
norburybrook
Just a direct swap. #102 ODS uses 220's so that was my rational when I couldn't find 300's :D
you could always clip in a pair of 80uf's in parallel if you wanted to hear if there's a noticeable difference.
Are you building a 100w amp? if you're building a 50w then you could argue that the main filtering should be halved anyway.
M
jfs322
Post by jfs322 »
Rubycon and Nichicon both make a 270uf 450v snap in cap. I believe you can find them at Mouser.
Lothy
Post by Lothy »
I've used the F&T 220 & 22 uF caps on my filterboard. They are not the cheapest, but very reliable. Made in Germany, I suppose (that's what they say on their web page). Well, I can't ask for more... :D
I can't see any advantage to pay 4 times more for Sprague.
Cheers
Gerhard
jcsifu
Post by jcsifu »
Lothy wrote: Mon Sep 28, 2020 6:12 pm I've used the F&T 220 & 22 uF caps on my filterboard. They are not the cheapest, but very reliable. Made in Germany, I suppose (that's what they say on their web page). Well, I can't ask for more... :D
Cheers
Gerhard
Sprague is not the same quality as they used to be in my experience. F&T has never given me any problems.
my .02
JD0x0
Post by JD0x0 »
Radials are cheaper, more plentiful, and tend to perform better if you can make them work with your layout.
It's true i've lost my marbles and i cant remember where i put them
pompeiisneaks
Site Admin
Post by pompeiisneaks »
JD0x0 wrote: Tue Sep 29, 2020 1:14 am Radials are cheaper, more plentiful, and tend to perform better if you can make them work with your layout.
Agreed 100% the ubiquity of SMPS in cpus and all other forms of electronics have really made radials last way longer, way better ESR, way better in every way...
~Phil
tUber Nerd!
Lothy
Post by Lothy »
Yes, lets drill some holes in the Fender doghouse :D :D :D
BTW, is that the reason for the double 47uF layout on the PB?
Cheers
Gerhard
Travis_HY
Post by Travis_HY »
Another vote for F and Ts. They are the best caps you can get these days and their cap cans are also the best. They aren't too bad price-wise and I have had better results with them than the newer (last 15 years) Spragues.
"Genius manifests itself. You got a hammer. You either build a Cathedral or you build a shithouse." - Carl Schroeder
joesnuffey
Post by joesnuffey »
Has anyone done the 100 watt build with any of the suggestions, and care to elaborate on how you feel about the route you went?
Richard1001
Post by Richard1001 »
For me personaly no F&T's. I don't like the sound of etched foil electrolytic caps in the power supply. I mostly use Mundorf and sometimes others with smooth foil.
They are a little bigger in size though.
WhopperPlate
Post by WhopperPlate »
Richard1001 wrote: Fri May 31, 2024 11:07 am For me personaly no F&T's. I don't like the sound of etched foil electrolytic caps in the power supply. I mostly use Mundorf and sometimes others with smooth foil.
Careful using your ears like that , you might start a war
Charlie
