Tweedle Dee / mods or not?
ChopSauce
Post by ChopSauce »
A few years back, I started randomly gathering a few parts for a Dee-luxe as a background task of the lowest priority
but Fred's build combining Mr Dee mods with Rob Rob's channel cascading pulled the trigger.
(amongst) EDIT(s):
- forgot about the idea to switch channels with a relay and intend to build the thing into a narrow panel tweed deluxe cab - and the corresponding chassis -
- changed titles to reflect project states.
norburybrook
Re: Finally: Tweedle Dee Fred
Post by norburybrook »
I got my whole set of parts from Mike @modulus amplification. He's a member here and put a kit together after we spece'd everything out for my build
https://modulusamplification.com/Modulu ... 75275.aspx
I like your idea of the switching.......I'd need Martin Manning to work that out for me though as I seem to have a blind spot with relays and switches.
I'll look forward to your build
M
ChopSauce
Post by ChopSauce »
I am not very used to the schematic of switches, either. I will have to look at this more in depth.
EDIT: I plan to achieve the 3PDT switching with two DPDT relays in parallel. Shouldn't that work?
NB: (not sure that may help you, Marcus) the schematic below shows the position for which the cascading is achieved.
In the other position (pole 4 connected to pole 1, pole 5 to pole 2 and pole 6 to pole 3), the connections are back to normal.
(dunno where I think I could read the switch achieves both cascading and paralleling... :? )
ChopSauce
Post by ChopSauce »
norburybrook wrote: Tue Jun 02, 2020 6:02 pmI'll look forward to your build
M
Thanks for your interest... 8)
Your samples https://soundcloud.com/marcus-cliffe/se ... sound-clip were amongst the most convincing ones to me, need I say. I also think I'll try the NFB switch, following your advice.
Two more links...
- Tweedle-Dee plus pre-PI Master Volume: https://ampgarage.com/forum/viewtopic.php?f=4&t=33384
- Cascading channels in the Tweedle Dee: https://ampgarage.com/forum/viewtopic.php?t=32027
EDIT: for the sake of completion, amongst the mods I could envision for this build:
- also suggested by Marcus, tuning the 680k resistor between cascaded channels - maybe -
- and I could see a presence control pot on the MojoTone tweed pro kit
which might be a worthy add-on to the NFB mod.
- and that https://www.tube-town.net/ttstore/kit-d ... r-6-v.html was the relay kit I was planning to use, possibly sitting under a dog house, on the back of the chassis.
ChopSauce
Post by ChopSauce »
So for the sake of completion, I made a list of mods - with links, above - but I finally feel like the original Tweedle Dee will distort enough for me, especially with the (rather) lower voltage power transformers that currently sell in Europe.
So, I think I'll build a stock Tweedle as a start, even though my daughter wants me to build it as a Ceriatone-Tee looking head
which somewhat appeals to much modding... :wink:
norburybrook
Re: Tweedle Dee / mods or not?
having returned to mine today later in the day, on stock settings the amp starts to break up at anything over 3 on the volume so there's plenty of gain/breakup available on a stock amp. If anything this amp needs less not more gain IMHO as it's hard to get any kind of real clean headroom from it at a reasonable volume.
I'm not sure these mods improve the amp now in retrospect.
M
p.s. that relay looks great, from a 6v heater tap as well. Thanks for the heads up on that. The mojo tone schematic looks very interesting. If you added cascading to that I recon that would be a great amp as it's using a AT7 with less gain in V1 and also i think the tonestack would adress the excessive bass issues and presence would be a nice adittion.
That's got me thinking. My chassis has 3 pre amp tube cut outs already I wonder if I could mod my board for this or would it be a completely new build.
ChopSauce
Post by ChopSauce »
The schematic is supposed to be a custom version of the 5E5 pro amp, from Fender - if I caught it well. Here it is: https://www.mojotone.com/kits/TweedAmpK ... fier-Kit_2#
norburybrook
ChopSauce wrote: Thu Jun 04, 2020 7:13 pm The schematic is supposed to be a custom version of the 5E5 pro amp, from Fender - if I caught it well. Here it is: https://www.mojotone.com/kits/TweedAmpK ... fier-Kit_2#
ah yes.
Here's a good layout. would be easy to mod this with the tweedle dee mods.
M
fred.violleau
Post by fred.violleau »
Guys, I spent the day modding mine as well with Martin's suggestion for the Master volume.
I ended up reverting back to what I had done in the first place. The MV made the amp sound sterile.
But adding a pot between V2A coupling cap and the PI entrance acts as a MV (sort of) and keeps the original caracter of the amp when pot is turned full on
I really enjoy the passive FX loop, works fine, although I am thinking of building a princetone clone so I get another small amp for a wet/dry or a clean/dirt setup ;).
I wish I had read about the single coil/humbucker switch, would be probably a great addition to deal with the extra bass on humbuckers as well.
BTW, this a great demo on how to understand the interactions between the volumes pots and tone pot on a 5E3
https://www.youtube.com/watch?v=VN2vqCxaeC0
Good luck with your build ChopSauce! This amp is great, but I had to buy a new set of JJs today since the old Sylvania I had just burned... It gets hot so better put on overspeced PT on this build so it runs cool.
Also, you may think about head vs combo, because in a combo, the chassis will have the tube heating the chassis. I have a tween build to complete with 715 caps vs 6PS caps (I know I am abit OCD sometimes) and I am thinking of putting this one in a head too, but the opposite way, so when it runs hot, it is not heating the whole chassis.
My 2 cents here ;)
Fred.
fred.violleau
Indeed, using the cascading option with a realy is a great idea! but it really brings in a lot more signal .... way louder.
So.. put a trimmer instead of the 680k on the cascading relay so you may play with it ! I would ground the excess signal (did this in my previous build per Marcus's suggestion and it worked great!) and let you dial how much of the chan 1 signal you want to add.
You don't need the whole gain channel 1 is able to send, eventually it turns into double distortion.. So you could cut it off before that happens.
ChopSauce
Post by ChopSauce »
Thanks for the report and the many suggestions. I think the caps on the original are 716P, not 715. I have attached a revised version of Phil's BOM(1). I am probably mistaking several things but this is my best guess at the components.
I read good things about a stereo setup using two (fairly) small amps so good luck with your next build, too... 8)
___
(1) https://ampgarage.com/forum/viewtopic.p ... 30#p375930
norburybrook
fred.violleau wrote: Thu Jun 04, 2020 9:35 pm Guys, I spent the day modding mine as well with Martin's suggestion for the Master volume.
I ended up reverting back to what I had done in the firstr place. The MV made the amp sound sterile.
My 2 cents here ;)
Fred.
Fred, thanks for the detailed reports and experimentation on this, valuable info for all builders. You'll love the princeton :D I made mine slightly bigger and used a Cannabis rex 12 inch speaker. It's great, again has a lot of bass but the tone stack means you can dial it out to suit. I also added a Dwell pot on the rear which makes dialling in the perfect reverb easy.
Guys, that video is using a standard tweed deluxe, if you build like the tweedle dee with separate cathodes etc then there is no volume interaction. :D
onwards.....
M
fred.violleau
Ha interesting!
My amp has interactions between the volumes and the tone. especially with the full on setting.
Even on channel 2 if I flip the cascading switch, it adds more texture to the sound. Maybe it is because I derailed from the original with the funky PI entrance.
I will bypass the pot today and see how it sounds. It looks like the way I arranged it is not harmful, but it is not the right way to do it either.
norburybrook
fred.violleau wrote: Fri Jun 05, 2020 12:33 pm Ha interesting!
all good Fred, that's why we're here, :D
I'm going to remove mine and just use the 470k Grid stopper, I think that sounded better :D Also I realise my bass cut switch doesn't work when in cascade more...need to look at that :D
I'm tempted though to strip this an build the 5E5-A pro and add the cascading mod. I think the T and B tone stack would be a good addition...... or just leave it stock and build a proper high gain Jose mod Marshall...... :D
M
norburybrook
If I remove the master and the tone control I could fit this tone stack
could someone tell me where the input and outputs are for this, and what coupling caps need to be added?
TIA
M
