DLite problems
G-Dorian
DLite problems
Post by G-Dorian »
I have a DLite that is sounding a little harsh, and it doesn't have the bottom end it used to.
When I turned it on yesterday, I didn't have any gain (no distortion). Although the Gain was on, it was clean - until I jiggled the middle preamp tube, then the distortion came back on. I figured part of the problem is the tube socket.
Would a bad tube socket cause the harshness and lack of low end? (This is just on the Gain, not the clean.)
ampgeek
Re: DLite problems
Post by ampgeek »
Interesting.
Since the OD tube is switched in and out in series with the CL tube, I would expect a "disabled" tube (e.g., due to a bad tube socket) to produce no sound as opposed to clean sound as you report.
How are you switching? Panel switch or relay system? Jiggling the tube may have caused the switching mechanism to engage.
I am not sure about how a questionable tube socket might effect tone. Sorry.
Dave O.
G-Dorian
Re: DLite problems
Post by G-Dorian »
The DLite doesn't have a footswitch, so I have to switch it on the front panel.
The clean channel seems to be fine. Like I said, when I turned it on, I didn't have OD (it was clean only) until I jiggled the middle preamp tube, then the OD came back on.
brownnote
Re: DLite problems
Post by brownnote »
I'd scrutinize the wiring on V2, re-flow the solder connections to the pins, and sub a new tube if the symptoms persist.
Remember kids...Always adjust for minimum smoke!
D'Lite Kits: http://store.bnamp.com/dlitekits.html
G-Dorian
Re: DLite problems
Post by G-Dorian »
Thanks, Moss. I didn't put it together. Norm did. :)
I tried a new tube, and that didn't change anything. I'll check all the wiring and soldering.
stelligan
Re: DLite problems
Post by stelligan »
What brownnote said. Also, it's very easy to overheat those front panel switches when soldering them. You said that wiggling the middle preamp tube sometimes fixes the problem? Try wiggling the switch - or just the chassis. You may just have a bad or cold connection - or an overheated switch.
G-Dorian
Re: DLite problems
Post by G-Dorian »
But would that also cause the harshness and lack of bottom end?
mlp-mx6
Re: DLite problems
Post by mlp-mx6 »
G-Dorian wrote:But would that also cause the harshness and lack of bottom end?
Maybe. It is clear from what you have said that there is a problem on that tube socket. Fix one thing at a time and you will KNOW what the problem was, and what was done to fix it. Take care of that socket, then report back, especially if there is still a problem.
Me: Just one more...
G-Dorian
Re: DLite problems
Post by G-Dorian »
OK. Thanks!
G-Dorian
Re: DLite problems
Post by G-Dorian »
brownnote wrote:I'd scrutinize the wiring on V2, re-flow the solder connections to the pins, and sub a new tube if the symptoms persist.
I re-did some soldering joints and swapped out a new tube in the V2. "Better," but there's still a little harshness. It's not horrible, but something just isn't right. I don't know how to describe it. It's like the texture of some notes sound . . . flabby?? Does that make sense?
But it's a harsh flabbiness.
Anyway, I'll keep going over things.
Thanks for everyone's help . .
brownnote
Re: DLite problems
Post by brownnote »
G-Dorian wrote:Thanks, Moss. I didn't put it together. Norm did. :)
oooohh OK, is it the #1 prototype amp?
G-Dorian
Re: DLite problems
Post by G-Dorian »
That would be the one. I had emailed Norm a few days ago and didn't get a reply . . until just now. (He was out of town.) He's willing to take a look, so I'll have him see if he can find something.
Thanks!
kleinm
Re: DLite problems
Post by kleinm »
G-Dorian wrote:That would be the one. I had emailed Norm a few days ago and didn't get a reply . . until just now. (He was out of town.) He's willing to take a look, so I'll have him see if he can find something.
Thanks!
Awesome! Hopefully you two will get down to the heart of it. Keep me posted.
67:1
ampdork
Re: DLite problems
Post by ampdork »
DC leakage offsetting next stage bias?
Something off at the tubes cathodes?
Funky socket?
G-Dorian
Re: DLite problems
Post by G-Dorian »
kleinm wrote:Awesome! Hopefully you two will get down to the heart of it. Keep me posted.
Will do, Michael . .
