to HRM or not
rutledj
to HRM or not
Post by rutledj »
Can someone tell me the tonal differences between the hrm and non-hrm?
Does one give a more "smoother" od than the other?
Also, what does the dlite version omit besides the hrm?
And, is the JFET ckt worth the effort?
Thanks,
Rut
heisthl
Re: to HRM or not
Post by heisthl »
rutledj wrote:Can someone tell me the tonal differences between the hrm and non-hrm?
Does one give a more "smoother" od than the other?Rut
If your a "tubescreamer" for solo kind of guy you want non-HRM - it is easy to get rich singing sustain. The HRM is less distortion like and much more dependent on touch for overdrive tonality.
rutledj wrote: And, is the JFET ckt worth the effort?
Thanks,
Rut
Nope - use a 150K-200k on the dropping string to simulate the load. Buy a MXR microamp or equivalent Fet pedal if you really need a FET stage before the amp.
www.RedPlateAmps.com
rutledj
Re: to HRM or not
Post by rutledj »
So would you say the HRM version has a smoother overdrive tone (less gritty/buzzy)?
heisthl
Re: to HRM or not
Post by heisthl »
A properly tweaked non-HRM is not gritty or buzzy but it is more distorted sounding at lower drive settings - in a good way. One cannot really imitate the other. The non-HRM emphasizes the mid harmonics more. To confuse you even more - Blues gig = non-HRM and Fusion gig = HRM of course this is just MHO.
TimS
Re: to HRM or not
Post by TimS »
Which one would you say is better for rock?
rutledj
Re: to HRM or not
Post by rutledj »
OK. Let's narrow it down by artist's sound. Say recent Larry Carlton tone
Pete
Re: to HRM or not
Post by Pete »
I think for rock you may want to explore HRM but it will be necessary to use together with the PAB on. Think of the M in HRM. just my $0.02.
dogears
Re: to HRM or not
Post by dogears »
Birdies say that LC has a special style HRM. Not like the schematics here. Also not at all like the 80s circuit. ;)
Funkalicousgroove
Re: to HRM or not
Post by Funkalicousgroove »
In my experience the standard 80's style amp is far more forgiving, and has quite a bit more compressed overdrive. It's no where near the compression of say a Boogie, but still has alot more than the HRM.
I personally prefer the HRM, with that circuit you get 4 really distinct tones: Clean, boosted clean, non-boost OD, Boost OD
the 2 in the middle are great in-between tones because of the lower gain. The boosted OD is REALLY expressive in that you can pick lightly and the amp is almost clean, but lay into it and it just screams!
If you are not a "Touch" player you might not like the HRM. the non-hrm definitely has more of that liquid sustain.
heisthl
Re: to HRM or not
Post by heisthl »
Funkalicousgroove wrote: the non-hrm definitely has more of that liquid sustain.
Exactly right - a good non-HRM can be like using an E-Bow. Truely liquid guitar/Therimin(sp?) feeling when it's dialed in.
Funkalicousgroove
Re: to HRM or not
I say build one of each and get a lehle switcher, HRM with EL34's and a non HRM with 6L6's
Runaway J
Re: to HRM or not
Post by Runaway J »
Funkalicousgroove
Re: to HRM or not
The first things I notice:
No gain trimmer
V2 Grids are reversed
So, Does this mean the topology goes Gain stage, tonestack/volume, recovery amp, gain stage HRM tonestack, gain stage?
The PAB also references ground, and the 2 22M's are tied.
dogears
Re: to HRM or not
Post by dogears »
I guess this means that the pic on the site is authentic. I have had it for a while. Funk is right btw. This is way different. Let's see what astute eyes point out..... ;)
heisthl
Re: to HRM or not
Post by heisthl »
any idea what the lower right resistor is doing? looks to be connected to the mid pot with a value of 1k8
