LC amps
llemtt
LC amps
Post by llemtt »
http://mr335.tv/
Enjoy "Tech Bench" section 8)
Teo
toneman
Re: LC amps
Post by toneman »
Thanks for the find. :D
Guy G
Re: LC amps
Post by Guy G »
When he talks about the amps, he mentions his cab with EVM speaker, he says it has cylindrical baffles to give it more harmonic content.. wtf is that?
Pete
Re: LC amps
Post by Pete »
Guy G wrote:When he talks about the amps, he mentions his cab with EVM speaker, he says it has cylindrical baffles to give it more harmonic content.. wtf is that?
cardboard tubes (ports) in the front baffle board that the speaker is mounted on. As seen in many stereo speaker designs, P.A. and monitors. back is closed I think.
dBe
Carlton cabs...
Post by dBe »
The cabinets are simply T/S designed cabinets that make the speaker "speak" the entire range that it is capable of reproducing. No big thing: plug in the numbers.
All I can say is that I'm 59 and I'm glad he didn't tell me anything I didn't know.
I'm REALLY glad that he reminded me of all of the things that I've forgotten, or blown off, that give the subtleties (magic) that I've neglected.
Maybe it IS a function of age :-) or :-(
, I'm still unsure... oh, wait... that's the Alzheimers.
Sheesh,
BTDT
Dave
Bob-I
Re: Carlton cabs...
Post by Bob-I »
dBe wrote:All I can say is that I'm 59 and I'm glad he didn't tell me anything I didn't know.
Damn... someone older than me... I'm just a baby compared to you (56) :lol:
Yes, he's a good communicator and doesn't keep secrets. I like that!!
Sheesh,
BTDT
Dave
Damn Dave, you ok there? It almost sounds like you might have...... wait, what were we talking about? :roll:
benoit
Re: LC amps
Post by benoit »
LC Masterclass in the latest Guitar Player, FYI.
mat
Re: LC amps
Post by mat »
llemtt wrote:http://mr335.tv/
Teo
Thanks llemtt 8) So much cool stuff in there :D Just enjoying the Larry and Robben performances 8)
mat
dBe
Re: Carlton cabs...
Post by dBe »
"Damn... someone older than me... I'm just a baby compared to you (56) "
Yeah, you're still a young buck.
"Damn Dave, you ok there? It almost sounds like you might have...... wait, what were we talking about?"
I might have a brain around here somewhere...
... there it is!
Back to speakers.
High Qts speakers (>.5 or so) are better suited for open baffles. Sometimes they can be used in closed boxes for bass use and guitar but they sound kind of constipated. I personally think that a speaker with a Qts over more than .75 should only be used in an open baffle. Then again, there are a lot of high Qts drivers being used in closed boxes f,or bass, so what do I know?
The old EVM12L speakers had a Qts of less than .3 if I remember correctly and the new ones are at .23. At this low of a Qts closed boxes are "best". .3 - .5 work very well in vented cabinets, with lower Qts requiring smaller boxes. One of the things that I like about Eminence drivers is the wide range of Qts low to high that they have. An alnico 10" has a Qts of 1.9! They have one that will work in about any box imaginable.
rutledj
Re: LC amps
Post by rutledj »
So would you recommend the celestion 12-65 in this type of box?
dBe
Re: LC amps
Post by dBe »
rutledj wrote:So would you recommend the celestion 12-65 in this type of box?
I have no idea :(
Celestion doesn't publish T/S parameters, I can't find them on the 'net and I've never measured one. Without the parameters, box design is just a stab in the dark.
Sorry.
Dave
skyboltone
Re: LC amps
Post by skyboltone »
dBe wrote:I have no idea :(
Sorry.
Dave
I've never seen any guidlines for open back cabinets using T/S parameters anyway. Those guys were interested in ducted ports and closed boxes. The old Altec boxes for VOT and the 604 series broke all the rules. I talked to an old Altec engineer about a set of 604-8Ks that I had where the published numbers are clearly wrong and he said ignore all that. Eight cubic feet for all the 604s. Size the port by ear he said. Sheesh.
dBe
Re: LC amps
Post by dBe »
[/quote] I've never seen any guidlines for open back cabinets using T/S parameters anyway. .[/quote]
I assumed the reference to the Reissue G12-65 was about using it in a vented cabinet. Maybe I missed point of his question. :shock:
T/S computations were gaining popularity here in the US in the early 70's. I have no doubt that HAD was into all types of research on the entire amp/speaker/cabinet system. Seems he is curious that way. Even his semi-open back cabinets appear to be tuned in some way. Probably by ear due to the size of the opening.
Just a trip into conjecture here. :?:
Dave
Pete
Re: Carlton cabs...
Post by Pete »
dBe wrote:The old EVM12L speakers had a Qts of less than .3 if I remember correctly and the new ones are at .23. At this low of a Qts closed boxes are "best".
Just wanted to clairify, L.C. uses the old EV (or has in the past) and the box is not "closed" (100%) :-)
Pete
Re: LC amps
Post by Pete »
I have a clone of the LC/HAD type box used with old EVM12L. Sound is what you would expect. I tried a reissue 12-65 in the same box and the result was more bottom/bass than the 12-65 in other (1x12 open back & 2x12 open back) cabs. FWIW
