Dumble with reverb - completed pics
				amplifiednation
#124 style amp with tweaked Normster style reverb
Designed the chassis and eyelet boards in Solidworks and had them punch pressed.
					Last edited by amplifiednation on Fri Nov 11, 2016 2:26 am, edited 3 times in total.
				amplifiednation
Re: Dumble with reverb - completed pics
Eyelet holes a perfect .128".  The rounded corners are awesome, very smooth G10.  Cleaned with isopropyl alcohol.
						- dorrisant
Tell us more!!
				amplifiednation
low plate classic with a few tweaks
100w 6L6
Ran the coax and wired up the tone stack RG188
						100w 6L6
				telentubes
Way to go Taylor. Can't wait to see how this project develops.
Lined chassis look great and boards turned very nice.
Will be looking for the sound clips
Niki
Niki
Are you doing pre or post reverb?
Here's a post reverb a customer wanted, and with tremolo.
				amplifiednation
Post OD.  Coming off the master and going right back to the same spot. I've gotten good results using the 1 tube design but I think the paralleled driver tube sounds fuller.
I haven't tried the pre.
V1/V2
V1/V2
Really great looking amp Taylor.
Aaron this looks very nice.
What tremolo did you implement?
And both - what global NFB values you used?
Thanks in advance,
Niki
Thanks in advance,
Niki
For this amp I used the bias tremolo.
Looks really good Taylor. Big project to put together but it looks like you're off to a great start. Good Luck!
									Why Aye Man
				amplifiednation
Thanks guys
Bias/rectifier/relay supply all loaded up on a side mount board. Matching G10 spacer and some nylon washers keeping the connections isolated from the chassis
Footswitch wiring. Leds on Lower Lugs
				amplifiednation
Board
Loaded up the board
				amplifiednation
Ah well kinda just got after this one today...fire her up tomorrow.
This was all lead-free solder with Kester 48 Flux. Pretty killer stuff, it wets like crazy. Smells awful though.
230v export transformer with aux relay transformer can get a little messy with the extra wires, but it's pretty clean overall. The rounded G10 boards are too cool. I decided to go one tube reverb on this one, we will see how big the effect is.
[img:5991:3472]http://i.imgur.com/aL80Ert.jpg[/img]
[img:6000:4000]http://i.imgur.com/VPyXlRQ.jpg[/img]
[img:6000:4000]http://i.imgur.com/PZ8AIhC.jpg[/img]
[img:6000:4000]http://i.imgur.com/HsgNZ98.jpg[/img]
[img:6000:4000]http://i.imgur.com/qcBVfoH.jpg[/img]
[img:6000:4000]http://i.imgur.com/nXfzypE.jpg[/img]
Amplified Nation
www.amplifiednation.com
@ampnation
@ampnation
