I know the dumblator is the king- but I'm curious
Fuchs Verbrator
Fuchs Verbrator
Thoughts? Has anyone tried one of these? The small foot print is appealing! It would fit nicely in the back of an ods head and one could easily power it from the courtesy outlet- no brainer concept- Nice part is you really never need to remove/disconnect it, could mount it inside, call it a day..
Re: Fuchs Verbrator
The verbrator pedal will work in your ODS as a tube buffered loop like a Dumblelator. The reverb in the pedal is not affected by the send level and will clip in an ODS amp. I believe you could have Fuchs modify the unit or possibly you could yourself, but in stock form the reverb could not handle the level especially with the PAB engaged. I ran a Hall Of Fame reverb in the verbrators loop and that worked well. The loop worked well and had a nice sound with the extra gain stage.
I ended up having my amp modded by Bill Dunham with a built in D-lator.
