And then there's this....
FUCHSAUDIO
Post by FUCHSAUDIO »
A mix of our Fuchs Clean Machine tone stack on channel one and the ODS (c) dirt channel on channel two with an overdrive tone control, two Fx loops, global master and accent control, our gain boost that works without bypassing tone stack, PLUS a tone stack bypass (for stupid amounts of gain). It allows the first channel to get into mild overdrive zone, while pushing channel two over the top....ODS-II....fan cooled aluminum chassis, built in bias test metering and external adjustments, 6-way footswitch standard. Second footswitch optional as is midi control. 50+100-W models coming, and pre-orders in place already....
Re: And then there's this....
Well, I'm glad to see you're making progress on your simple, easy, "beginner" model amp, Andy. Nicely done.
:lol:
groovtubin
Post by groovtubin »
FUCHSAUDIO wrote:A mix of our Fuchs Clean Machine tone stack on channel one and the ODS (c) dirt channel on channel two with an overdrive tone control, two Fx loops, global master and accent control, our gain boost that works without bypassing tone stack, PLUS a tone stack bypass (for stupid amounts of gain). It allows the first channel to get into mild overdrive zone, while pushing channel two over the top....ODS-II....fan cooled aluminum chassis, built in bias test metering and external adjustments, 6-way footswitch standard. Second footswitch optional as is midi control. 50+100-W models coming, and pre-orders in place already....
Andy, it just tickles me you have the time $$$ and foundation to do this, my best wishes for success, n it`s a SURE thing! Looks and sounds fantastic!
Warmest regards, jim@Omegaamps
CHIP
Post by CHIP »
Cool, a bias meter.
stelligan
Post by stelligan »
CHIP wrote:Cool, a bias meter.
That is very nice :!: Cool cab as well.
Guy77
Post by Guy77 »
Very nice! I love the wood finish.
How many preamp tubes in total?
Cheers
FUCHSAUDIO
Only 4 preamp tubes total. Clean, OD, Loop, PI.
jelle
Post by jelle »
Nice job! Gutshots?
FUCHSAUDIO
Not really into broadcasting what we're doing Jelle, but here's a taste.
jelle
Post by jelle »
That looks great. :D
JazzGuitarGimp
Post by JazzGuitarGimp »
Great looking amp, Andy! I see you are not using solder masks on your pcb, is this a cost-reduction measure, or is there a functional reason for this?
FUCHSAUDIO
The main board is a prototype, so no mask. The power supply board is our standard ODS board. Our production boards are all two sided, solder mask, silk screened etc. good eye !
Smitty
Post by Smitty »
Are you bypassing the lytics with plastic caps? Nice. I like the way that sounds.
JazzGuitarGimp
FUCHSAUDIO wrote:good eye !
LOL - 31 years of pcb layout will do that to a fella I s'pose!
jam-mill
Post by jam-mill »
The built-in bias metering was also implemented on the Weber AB200 bass amp https://tubeamparchive.com/viewtopic.ph ... c&start=51
John 15:12-13
