This thing sounds glorious... As long as I keep the reverb return pot down, barely cracked at all. It sounds good there, sounds like the reverb hall from hell above that. I noticed the floating ground for the tank return on the schematics posted so I tried that. That was an ear piercing experience.
It seems the effects loop is too sensitive as well. I've checked through component values and connections a few times but I could be missing something.
I'm wondering if any of you guys that have built these have encountered anything like this. Or if anyone else had any suggestions please do so.
As it is:
50 watt layout
Voltages seem to be in line with know good clones
DC filaments on the preamp tubes
Bias circuit is on a separate PT tap
Totally different layout
No hum off hiss (OT had to be there)
Need to etch the front and back plates yet
Many thanks to mhartman, Aaron and Mark Fowler for the great info and posts. Thanks to Taylor for the tolex tutorial. Sorry if I left anyone out!
I can post more (specific) pics or info if needed, just ask.
