I built one of the Ceriatone 50W FM OTS. This was my first build and it seemed to go ok. I got it up and running first time. The clean channel sounded good however the OD section was quite harsh and I wondered if I had made a mistake wiring it up. Anyway I just left it and didn't use the OD section. A few days ago I switched the amp on and had absolutely no sound. When I opened it up I noticed my phase inverter tube was cracked!! Is there anything electronic that could have caused this?
I have a link to pictures which I will update this post with once I get home to my computer.
For reference I used JJ ECC83S tubes.
Any help that you guys could offer would be most appreciated!
I can't remember exact Plate voltages from when I built it but they were high 400s as expected.
The other problem is that the Drive Ratio and OD trim pots have no influence over the OD section when the Pedal activated the OD. They function as they should when the OD section is activated on the back.
Also, the OD section sounds very harsh to me, certainly not smooth and sustaining violin tones like Robben (although I appreciate i am not RF, this sounds like something is wrong!)
The pictures are here
http://www.flickr.com/photos/94683768@N03/
One adjustment has been made since these photos were taken, the blue and brown output transformer primaries have been switched around since then as this was a problem i had and then solved with Nik to get the amp to initially start up.
Any help would be hugely appreciated!
