I'm going to use the CE Pedals black chassis and Agbamplifiers boards. I figured I just use the precision PS and newer-era bias board layout since that's what the Agbamplifiers boards are set up for. I'm also ditching the courtesy outlet, ground switch and 1/2 power switch since the chassis doesn't really have holes for them and I don't really think I'll need them anyway. I also figure I'll put a LNFB bypass switch in the impedance selector switch hole since my OT only has a 4 ohm tap.
For iron I've got a '68 Showman PT, and a '73 Quad Reverb OT and choke. I also snatched 1 CTS 1M audio, 2 2-35 250Ks, and a 1 100K Linear pot from the Quad. I'm using PEC pots for the rest. I'm not sure which controls I'll use the CTS 1M and 100K for since volume, master, drive and ratio all seem to be pretty critical. Hopefully the PECs sound decent. I have a buch of Piher carbon films on the way for most of the signal resistors, and Electra MF7Cs for the plates and cathodes and a few other places. I'm going to use mostly NOC carbon comp for the rest of the signal resistors since I already have a whole bunch of them.
Here's a picture of what I've amassed so far for the build.
[img
I'm really looking forward to putting this together since it's a pretty interesting challenge complexity-wise. Hopefully I can get it sounding decent enough to be part of my main live rig.
-Aaron
