Built inside D-lator
uriuri
Post by uriuri »
Hi!! I'm in the middle of building a Ceriatone OTS 50 and I was wondering to build a D-lator inside the chassis using the power section of the amp... Any tips?, problems?... I read about the noise it cause if the loop is built inside... Is there a better way to do this... some Schematics? Any help or advice will be appreciated! Thanks guys!!
Re: Built inside D-lator
Looks like you need to do some research.
The answers can be found in the Dumble Files section. :wink:
husky
Post by husky »
uriuri wrote:Hi!! I'm in the middle of building a Ceriatone OTS 50 and I was wondering to build a D-lator inside the chassis using the power section of the amp... Any tips?, problems?... I read about the noise it cause if the loop is built inside... Is there a better way to do this... some Schematics? Any help or advice will be appreciated! Thanks guys!!
Sure you can shoe horn it in but it won't sound the same as an external box due to cable capacitance. Part of the magic for most people. If you are space challenged though and want a good loop that is transparent you can build one out of high voltage mosfets. No extra tube or heater current to worry about.
______
John Suhr
www.suhr.com
pedro
Post by pedro »
John thats very interesting, and I hadnt thought about that
I'm currently building an internal one, as I have a spare socket in my donor chassis, and have space to hardwire the components on terminal strips around the socket.
I guess I could simulate the cable run capacitance by adding some capacitance to the input/outputs ?
Rgds
Pete
Yes
pedro
Post by pedro »
hmmm,
maybe 100pf at both in/outs to simulate a few feet of cable each way ?
Rgds
PeteC
Greg (Boldaslove) has experimented with this and says in this thread he used a .0022uF
Here is the thread, he makes a mistake and says .022 at first then corrects himself later down the page.
https://tubeamparchive.com/viewtopic.ph ... 441#194441
pedro
Post by pedro »
Great - thanks for the link Tom
Rgds
PeteC
10thTx
Post by 10thTx »
I drew this up a while back based on someone's use of this idea for a reverb. I have NO idea whether this will work or not?
It is just a DRAFT idea that is unproven (as far as I know).
I am simply posting it for the purpose of discussion & to see if someone who knows mosfets can offer some insight as to whether this would work?
With respect, 10thtx
uriuri
Post by uriuri »
Thanks everyone! (john, thanks also for these fantastic guitars that you and your team build! I own one and i'm in love!)
Post by Mark »
I wouldn't get too worked up about capacitance of the leads. I like the effect of driving the cathode follower. I also like the bright switch on the send control too.
I've tried high capacitance cables and it does thicken the overall tone of the amp but at the expense of the clean tones.
Yours Sincerely
Mark Abbott
wavetuner
Post by wavetuner »
This is an intriguing idea. Has anyone actually built a power Mosfet circuit like this and tested it? If so how did it compare to the real deal d-lator? Perhaps this is a bit of heresy in a purely vacuum tube signal path though.
Joost
Location: The Netherlands or Holland. Whichever you prefer
Post by Joost »
I built a dumbleator inside my ODS 100W (#124) and powered it using the ODS power section as a basis.
I made a schematic and a layout:
https://tubeamparchive.com/viewtopic.ph ... highlight=
