Hrm 100 bluesmaster from PA 100
wally19840
Post by wally19840 »
HI, I have been away for awhile but I am back and looking to build an Hrm Bluesmaster 100 watt. I want to use a 70,s model Fender PA 100. I am told that the iron is the same as the twin reverb. This amp also has reverb. I need your thoughts and comments about this build. Any thing you can contrbute would be greatly appriciatted.
Thanks in advance.
Re: Hrm 100 bluesmaster from PA 100
Yeah it looks like both the PT and OT are the same part numbers as the Twin Reverb.
You should be able to use the reverb transformer and tank most likely.
Sounds like a great platform to convert to a Dumble amp.
I haven't attempted a Bluesmaster yet but several here have.
You just have to figure out what schematic and layout to use.
amplifiednation
Post by amplifiednation »
Fuchs has been using some of those PA100's for awhile for some ODS mod projects with extremely good results. It's a good platform for sure. I know Andy made some killer amps for the customers that brought him the PA's. The cabinets are huge!
Amplified Nation
www.amplifiednation.com
@ampnation
