Latest project - '90s HRM w/Dumblelator
Normster
Post by Normster »
You guys have finally piqued my interest. Here's the layout with a few of Dogears corrections: (I haven't incorporated the Master bypass yet.)
[img:2318:1255]http://bad-domain/97HRM/97_ODS_HRM_Loop.JPG[/img]
Feel free to provide feed back, etc. (BTW, this will be built as a head with the trannys and tubes facing UP.) A few deviations from the typical Dumble layout:
1. Mains/Standby switches moved to the front.
2. Bias test points added and bias pot moved to the back panel
3. Mid switch changed to Treble shift (per Dogears recommendation)
Trannys are 100W Marshall PT and 80W Fender Twin OPT from Weber. If these trannys are crap, let me know and I'll throw up on ebay and get good ones. :lol:
dogears
Re: Latest project - '90s HRM w/Dumblelator
Post by dogears »
Norm,
OD1 coupler...
Normster
Post by Normster »
dogears wrote:Norm,
OD1 coupler...
.0022uF? I didn't even notice that. :oops:
Should I also change the PI input to .01uF?
Bob-I
Post by Bob-I »
How about posting the visio file. Easier to read that way.
Bob-I
Post by Bob-I »
A few suggestions that diviate from the Dumble layout, but worked great for me. Take 'em or leave 'em, just suggestions.
Put the HRM right on the main board, check my layout for the other mods to make this work, like moving the cathodes. It keeps the leads shorter and removes potential instability.
Use a switched stereo jack for the foot switch. Run the relay wires to the non-switched side of the jack, then the switched side to the front panel switches. Plugging in the footswitch automatically disables the front panel switches.
Get earplugs, this sucker's gonna be loud. :roll:
Luthierwnc
Post by Luthierwnc »
I think the Send bright cap might be a little too generous.
I did a little soldering tonight on my Dumbleator Hybrid and wanted to know what you came up with on in the way of plate voltage.
sh
Bob-I
Post by Bob-I »
Luthierwnc wrote:I think the Send bright cap might be a little too generous.
I agree, but Norm used that on his 6V6 amp and liked it. Maybe some of his HF hearing is gone :? . I'm using 120pF and thinking about lowering that, it's pretty drastic.
Normster
Post by Normster »
Bob-I wrote:How about posting the visio file. Easier to read that way.
Here ya go...
http://bad-domain/97HRM/97_ODS_HRM_Loop.vsd
BTW, I've updated the .jpg and .vsd with corrections. I'll put the final version in the files section after I've completed the build. (Just want to make sure it works before someone else tries it. :D )
I put the HRM on a piggy-back board just in case I hate it. It'll make it much easier to convert back to an '80s amp that way. I'm such a coward. :wink: I actually have another layout for a twin conversion that has the HRM on the board. I'll send you a link.
I can't help with voltages yet. (Haven't built it.) As for the 270pF on the send, that's just what was on the schematic. I'll adjust to taste once I've heard it. I do like it on my 6V6 bright switch, but usually just when playing clean on the neck pickup. It adds an almost accoustic quality to the recorded tone.
Luthierwnc
The 270 puff is on the return. You show a .01 on the send and the schematic calls for a .001. sh
Normster
Post by Normster »
Luthierwnc wrote:The 270 puff is on the return. You show a .01 on the send and the schematic calls for a .001. sh
Gotcha. Fixed, and thanks for catching that!!! :D
Bob-I
Post by Bob-I »
Normster wrote:Here ya go...
Thx... looks good at first glance. I'll spend some more time later.
It is VERY different. Still Dumble but a completley different feel to it. Yoyu also have to adjust the cathode caps. Basically you drive the bass in CL1, CL2 and OD1 with 5uF caps, then drop some of it off on OD2.
I justs bought an ON-OFF-ON switch for my Princeton transplant. I'll use 120pF and 270pF for 2 different bright settings. I find the 270pF too much for a Strat but nice the a Les Paul neck PU.
Once again, nice drawing Norm.... cain't wait to hear the amp.
dogears
Post by dogears »
Bob is right.... You must replace OD2 bypass with a 1uf! Important....
Bob, the guys were referring to the Dumbleator bright switches. I leave them out of the circuit btw. No use for them.
Tdale
Post by Tdale »
All the cap values mentioned here does not necesserily apply to my Hybrid-a build, right?
Tommy
Normster
Post by Normster »
Thanks for the advice. I'll update the cathode bypass value. (With so much talk about 10uF, I guess I forgot that the HRM is a different animal.)
Tommy, YES the Hybrid-A and the HRM we're discussing are quite different. It gives me a whole new level of respect for Gary and his Glaswerks amps with their switchable voicing. :o
Bob-I
Post by Bob-I »
Tdale wrote:All the cap values mentioned here does not necesserily apply to my Hybrid-a build, right?
Tommy
You're correct. The Hybrid is completley different.
