Slope resistor switch
angelodp
Post by angelodp »
Just wondering if any have implemented a select switch for the slope resistor. Say 150/100
Bob-I
Re: Slope resistor switch
Post by Bob-I »
Not on a Dumble type, but a friend of mine swears by a slope resistor pot. He puts in the minimum resistance he wants in a fixed resistor and adds a pot in series. I saw a Marshall he did with a 33K and 100K pot. Very effective. Minimum slope was 33K, max 133k.
angelodp
interesting
Post by angelodp »
Ok so how does the high DC get handled. Can you suggest a method for the Dlite.
Have you tried a different slope resistor in your amp Ange?
The next time I have my amp open I'm going to try a 120K and if I don't like that, then a 100K.
It's supposed to make the bass and mid pot more audibly adjustable.
Right now I don't feel that my bass and mid pot do much.
Sure if I turn them both all the way down I can hear it.
I know they are somewhat interactive, it just doesn't seem like a good management of bass or mids in my amp.
dave g
Re: interesting
Post by dave g »
angelodp wrote:Ok so how does the high DC get handled. Can you suggest a method for the Dlite.
There is no DC across the slope resistor.
JD0x0
Post by JD0x0 »
i suggested a slope resistor pot a while ago. on my new amp it isnt possible since i have the HRM on the front panel also. I have a switch that puts a 76K resistor in series with the 33k so it's selectable between 33K and about 100K
It's true i've lost my marbles and i cant remember where i put them
Firestorm
Post by Firestorm »
Bob-I wrote:Not on a Dumble type, but a friend of mine swears by a slope resistor pot. He puts in the minimum resistance he wants in a fixed resistor and adds a pot in series. I saw a Marshall he did with a 33K and 100K pot. Very effective. Minimum slope was 33K, max 133k.
Almost exactly what Mike Holland did on the Little Jimi amp. It was described as a way to adjust the response of the tone stack for different guitars and pickups. As Dave G says, there's no DC through the resistor, but there is a pretty high voltage potential. Maybe not so great to bring that out to the control panel in case a lead comes loose. Holland blocked the plate voltage with something like a .1 so there's a little effect on frequency response.
Bob-I
Re: interesting
Post by Bob-I »
Oh yea, I forgot about that. There IS about 200V DC on that resistor. You'll need to put a coupling cap before the resistor to block that DC. I'd use a .1uF from the plate of V1a to the tone stack.
kd
Post by kd »
Unless I'm screwed up on my thinking today(possible), there has to be DC voltage at the slope resistor. It would be seeing whatever voltage the plate is seeing. Am I wrong?
Ken
ayan
Post by ayan »
kd wrote:Unless I'm screwed up on my thinking today(possible), there has to be DC voltage at the slope resistor. It would be seeing whatever voltage the plate is seeing. Am I wrong?
Ken
You're right, Ken. Exception would be if there were a coupling cap after the preamp tube and before the tone stack, which I believe Andy still does in the Fuchs amps.
Gil
Would a DC blocking cap there affect the tone?
I've noticed before sometimes my volume pot gets a little scratchy.
Not bad enough really to address but there nonetheless.
talbany
Post by talbany »
Structo wrote:Would a DC blocking cap there affect the tone?
Yeah.. It effects breakup.. Never cared for it myself..
dave g
Post by dave g »
Ken
Gil
Come on guys :roll:
No, there is no DC voltage across the slope resistor.
While one end is connected to a DC potential at the plate, the other end is only connected to the bass and mid caps - so how can any DC current possibly flow through the resistor?
There's just as much DC current flowing through the slope resistor as there is flowing through a volume pot connected to ground (read: NONE WHATSOEVER) , because after all "ground" is still "DC" (just at 0 volts).
The only potential hazard would be one of the potentiometer lugs shorting to the case, and hence the chassis. Personally, I'd be more afraid of dielectric punchthrough in a coupling cap, or the grid of V1A shorting to the plate...
talbany
Post by talbany »
Actually it would need to be wired like a variable resistor.. If you ground the bottom like a Volume control you will be shunting voltage to ground. For a Dumble style stack I would add a 100k linear pot in series with a 50k fixed resistor so that you could adjust it from 50k to 150k..Keep in mind it might scratch..also if it's carbon trace it will effect tone.
angelodp
pot
Post by angelodp »
This is great info. Is there any particular pot manufacturer you would recommend, or is it all the same. I suppose it could be a trimmer set-up, but an off-board setup on the rear panel might be cool.
