EL84hrm
mat
EL84hrm
Post by mat »
I just recorded one clip of my (AX84.com) P1 to HRM project: http://soundclick.com/share?songid=8895338
I used my ES-339 to EL84hrm with DIY tube spring reverb (a very little reverb) on the passive loop and going into single RWB 12''. I used one SM57 and one other dirt cheap mic about one inch from the grille. The mics were connected to TB202 mic pre into M-Audio soundcard of my PC. Zero processing on the PC.
After 30 sec I turn the PAB on. The OD master was on 5. The drive was at... quite high. I'll record something with less drive and more sivilized :roll: when I have the time.
cheers,
mat
Re: EL84hrm
Sounds great! :D
I wish my D'lite sounded like that!
erwin_ve
Re: EL84hrm
Post by erwin_ve »
mat wrote:I just recorded one clip of my (AX84.com) P1 to HRM project: http://soundclick.com/share?songid=8895338
cheers,
Mat that was great! Please don't go too civilezed, this really rocked
Deric
Re: EL84hrm
Post by Deric »
Nice Mat!!!
Deric®
BobW
Re: EL84hrm
Post by BobW »
Nice tone, who would have ever thought, an EL84 HRM?
Colossal
Re: EL84hrm
Post by Colossal »
That sounds great. Can you post some details about the amp? Forget civilized, go for overdrive! Sounds really good man.
67plexi
Re: EL84hrm
Post by 67plexi »
Mat nice mids. I love the mini el-34 (el-84) It has that VOX chime.
I would like to build one can you share the onfo on this one ?
If you can be so kind. I need a low watt amp that sounds good.
Steve.
stelligan
Re: EL84hrm
Post by stelligan »
Extremely cool sounding amp and very nice playing. Congratulations!
mat
Re: EL84hrm
Post by mat »
Thanks for listening and for the kind words ! Sure, I'll share everything. I'll try to answer every question I can (quite busy these days at work...erhm.. working right now :oops:)
The power section is same as on AX84.com HiOctane. The mid pot is replaced by one 120k resistor. Pre volume is a trimmer (usually always on twelve o'clock on my d-style builds.) Bass and treble pots are still wired wrong way..krhm. The layout is far from as in original amps. The voltages are bit strange right now. 260-270V on the EL84. V1a,b about 155V. V2a 145V and V2b is 185V ??!!
PT is a small toroid. OT is Hammond 125ESE (IIRR).
The HRM settings are super sensitive for the OD sound. Bass trim is opened as little as possible. OD entrance trimmer is less than 50% on.
The preamp values IIRR are as on 101-HRM schem.
Back to work..
mat
Zippy
Re: EL84hrm
Post by Zippy »
Sweet!
I preferred the tones in the first 30 s but the whole groove is most musical.
Thanks.
stelligan
Re: EL84hrm
Post by stelligan »
mat wrote: The HRM settings are super sensitive for the OD sound. Bass trim is opened as little as possible.
Those bass trims always seem to function as on-off switches, don't they? A PITA.
ChrisM
Re: EL84hrm
Post by ChrisM »
Make the bass trim 500K for a more usable range out of it. Less on-off and more range from it.
Re: EL84hrm
Is the bass trimmer typically 1M?
I have these values on a couple schematics TMB, 250K, 20K, 1M
On the Brown Note Blue Monkey it has all 250K trimmers.
Then on another HRM layout it shows the typical 250K, 20K and 1M.
I have been considering adding a HRM board to my D'Lite. :P
ChrisM
Re: EL84hrm
Post by ChrisM »
1M, 250K, 25K are the standard values.
My suggestion was to change the 1M to 500K.
Simulate it in TSC with all linear pots, you'll see.
odourboy
Re: EL84hrm
Post by odourboy »
Very tasty Mat! 8)
