No Worries Tyler thanks for posting those!
Tony, the bands on the series plate resistor look a little orange to me. Maybe 430k.talbany wrote: ↑Wed Mar 17, 2021 3:43 pm Thanks Tyler
It looks as though the shots you have he's changed the value of cathode resistors to (530.17 ohms) 820/1.5k
BUT? he also changed the value of the plate resistors as well to 320k 100k+220k..If you take a look at #38 it appears he did the same to those plates as well..He's changed both RP and RK values..Someone want to do the math?
BTW.I think it's the same amp #38..
Tyler you got any more![]()
I looked at them on 2 seperate monitors and they still look red to me? Sometimes these color bands can be deceiving..Charlie Wilson wrote: ↑Thu Mar 18, 2021 6:17 amTony, the bands on the series plate resistor look a little orange to me. Maybe 430k.talbany wrote: ↑Wed Mar 17, 2021 3:43 pm Thanks Tyler
Tony![]()
CW
I'm sick of people asking for more gain, there you go, get out of here gain mod.
https://ampgarage.com/forum/viewtopic.p ... 80#p425180gonzomode wrote: ↑Fri Mar 19, 2021 1:05 am Is this one of the Dumbles sold by the Roy brothers in Germany late 70s? According to an article I read in a german magazin years ago, these Dumbles were produced in a small batch(a dozen or so) with identical circutries. I‘m relativly new to this amps, but my first impression is this is not a mod Dumble did. Maybe the first Kitty Hawk „prototype“![]()
It's at the bottom of the first post on the first page. It's being downloaded (4x so far). Let me know if you still don't see it, I might need to take it up with the moderators.
talbany wrote: ↑Sat Mar 20, 2021 8:46 am Well since I basically hijacked your thread.I am not exactly sure what your asking?
I implemented Martins FET boost relay circuit,works great and the switching is simple!.The footswitch basically grounds out (de energizing) the relay coil and light on the foot box, switching the inputs through the relay,super simple and works. Wire it (or draw it) up exactly as drawn up and you should be good to go.
Good Luck![]()
The pot pull switch is providing exactly the same function as the manual/pedal switches for OD and PAB, and it will engage the FET boost regardless of whether the footswitch is pugged in or not. I'm not sure why you would want another switch. In the relay control circuits you are free to choose which relay coil state engages the function.Stephen1966 wrote: ↑Sat Mar 20, 2021 10:52 amIn M's design the DPDT pot switch only appears to control whether the circuit routes through the pedal or not: a Manual/Pedal switch, like those on the back panel for the OD and PAB.
The FET circuit in my understanding, can only be closed (relay de-energised) either by the footswitch, or by not plugging the pedal in and switching from Manual, to Pedal. Switching to Manual energises the coil and activates the boost, by opening the circuit (to ground), switching to Pedal - without a pedal - would leave the circuit closed (no route to ground). These seem to be the only way we can activate/deactivate the FET boost. To get around this, I placed a simple (on-off) switch carrying the +12V supply before the coil. This switch, and its indicator LED, isn't in Martin's design. Please correct me if I am wrong.
