YAOB (yet another one-zero-two build)
Re: YAOB (yet another one-zero-two build)
You could get by with a 5A, the mains fuse in the amp is a 5A, albeit a slow-blow. Usually you'd bring the voltage up slowly too. That said if you're buying one, I think a 10A would be better.
talbany
Post by talbany »
3 amp Slo-Blo is what Dumble rated
T
I see you are right Tony. So how did the CE chassis get marked 5A, I wonder?
And, rated power on the Twin Reverb PT only rolls up to about 1.5A on the primary, so 3A would be a 2x margin (not including start-up surges).
talbany
Post by talbany »
5a is over kill..I think the SVT bass amps are rated 5a
I've run 2a slo on them before but have blown a few at in rush..
I agree based on the PT rating. So how big is your Variac? I like big ones so I can make my vacuum cleaner sound like a turbine...
talbany
Post by talbany »
Yeah that's cool,and looks great on the bench I'll bet.. Mine is just a 5a cheap China..Early on I used the variac a bunch but hardly ever anymore..I think the last time was to form some caps..The new reset fuses are cool..There great if you want to keep a closer tolerance and not have to keep extra fuses.
Max
Post by Max »
talbany wrote:3 amp Slo-Blo is what Dumble rated
martin manning wrote:I see you are right Tony. So how did the CE chassis get marked 5A, I wonder?
If you look at all the pictures here http://www.roblivesey.com/dumble/ you'll see that on original 2nd, 3rd, transition and 4th generation 100W chassis the fuse is specified "3 AMP SLO-BLO" and on original 5th and 6th generation 100W chassis the fuse is specified "5 AMP SLO-BLO".
All the best and a great weekend to all here!
Max
That is weird.
#124 has a 3 Amp fuse and the newer ODS have 5 Amp.
I see that Robben's #102 has a label over the screen printing with a 5 Amp label.
So maybe the 3 Amp was borderline that could blow after a while or depending on the wall voltage.
Max
Post by Max »
martin manning wrote:And, rated power on the Twin Reverb PT only rolls up to about 1.5A on the primary, so 3A would be a 2x margin (not including start-up surges).
Structo wrote:I see that Robben's #102 has a label over the screen printing with a 5 Amp label.
IMO the PT on this picture of #0102 seems to be larger than a Twin Reverb PT. And if Tony's layout of #0102 is correct, then the PT in the original #0102 isn't a Fender Twin Reverb PT but a Fender 026554 multi volt PT that AFAIK can be used with line voltages from 100V up to 240V: https://tubeamparchive.com/viewtopic.ph ... 264#140264
Max
aflynt
Post by aflynt »
Max
I think Martin was referring to my amp which does have a Twin Reverb PT there. Either way I'm guessing a 5 amp Variac would work fine. I'm going to ask around and see if there's anyone locally that I can borrow one from to measure the voltages in the amp with 120VAC coming in.
Thanks again for all the help!
-Aaron
You can adjust your measured voltages by the ratio of 120/actual line voltage and get pretty close.
aflynt
Post by aflynt »
martin manning wrote:You can adjust your measured voltages by the ratio of 120/actual line voltage and get pretty close.
Okay. So given my previous three measurements (428VCD B+ @ 118VAC Line, 414VCD B+ @ 116VAC Line, and 424VCD B+ @ 116VAC Line) the B+ at 120VAC Line with this PT would be somewhere between 428VDC and 438VDC. Since according to talbany these PTs (Twin) are usually dead on 450VDC, I think I will wire that Showman PT in there tonight and see how things go.
-Aaron
My Magnetic Components Twin Reverb PT has a plate voltage of 436v biased at 31ma with a wall voltage of 119.2vac
There are a few factors that will change the plate voltage.
I think if you are in the 430-450 range you are fine.
aflynt
Post by aflynt »
Structo wrote:My Magnetic Components Twin Reverb PT has a plate voltage of 436v biased at 31ma with a wall voltage of 119.2vac
Hmm... Maybe I just have it biased too hot. I've been running it around 41ma figuring that's about 60% of max assuming 30W tubes. Do you guys usually bias the Winged C's for 60% assuming 23W or 30W max?
-Aaron
boldaslove6789
Post by boldaslove6789 »
-Aaron
Might want to Bias @ around 32mA, 41 seems kinda high.
