Complete Build VLOG For My Latest 102
talbany
Re: Complete Build VLOG For My Latest 102
Post by talbany »
norburybrook wrote: Sat Jan 19, 2019 10:48 am Morning all.
Quickly as I'm about to start work in the studio. I think I should profile the amp with one microphone and get a set of base settings as it is then do the same after it has been modified, that will be then there forever.
I will also play the amp over a day just to tine my ears in before I do the switch so hopefully and changes will be easier to feel/hear.
I was thinking about using a looper so the performance would be the same but that would give me any 'feel' of the amp and that's as important as overal tone too.
lot's to think about and I want to finish my #183 first so this thread will be on hold for a while I think.
Marcus
Marcus
Just as a reminder. Don't change any settings on the amp after the swap
Good Luck!
didit
Post by didit »
While all resistors are loose on the bench measure, confirm and note actual resistances.
Best .. Ian
norburybrook
Post by norburybrook »
didit wrote:While all resistors are loose on the bench measure, confirm and note actual resistances.
Best .. Ian
Actually that's a good point. I will.
Marcus
Sent from my Nexus 6 using Tapatalk
Charlie Wilson
Post by Charlie Wilson »
I'll save you some time. They all measure within 1% of 102k. :D
CW
norburybrook
Charlie Wilson wrote: Sun Jan 20, 2019 2:06 am I'll save you some time. They all measure within 1% of 102k. :D
CW
:D of course, they are high quality metal films with small tolerance.
M
didit
Post by didit »
The set coming out.
Charlie Wilson
And going in. Same Dale RN65D just the pre Vishay version from 1980.
CW
talbany
Post by talbany »
80's Dales
didit
Post by didit »
Trust, but verify.
