tonelab2 wrote:What would be the value/wattage of the resistor for the RF mod?
thanks
Sweet...
groovtubin
Re: Sweet...
Re: Sweet...
Thanks groovtubin.
What wattage would be best or to put it another way, how many charlies?
thanks again
thanks again
Re: Sweet...
groovtubin
where do you get the 78Ohm value from for the 50watter - I have used a 500Ohm - is this overkill ?
cheers
Pete
cheers
Pete
Re: Sweet...
I think I'll use a 25watt, should be enough.
Where the 78ohm measurement came from I've got no idea.
groovtubin
Re: Sweet...
tonelab2 wrote:Thanks groovtubin.
thanks again
groovtubin
Re: Sweet...
pedro wrote:groovtubin
cheers
Pete
Re: Sweet...
I've used both a 500Ohm 25 watt and more recently a 1KOhm 10 watt due to something I read somewhere about changing the feel of the amp. I need to A/B them to see if there is any difference.
Re: Sweet...
Jim,
You are sure shooting from the hip with your size recommendations. The choke replacement resistor needs to be sized large enough to allow the screens to sag a bit. The 50 watter should get a larger resistor than the 100 watter due to the screen demands. If you use to small of a resistor you will not get the full effect of the screen sag.
I like 250ohm to 500ohm depending on amp wattage. I also like a switch to go between the choke and resistor. If the choke is roughly 100ohms then the resistor should be a bit bigger so there is a noticeable change when switched.
You don't need 25 watt resistors... Way overkill. Mouser has nice cement 5 or 10 watters that work just fine.
Re: Sweet...
thank you learned friend
Ive used 2 x cement 1K 5w in parallel.
I have a spare partidge choke and hammond choke so when amp is finished I will try all 3 and report back.
cheers
pete
cheers
pete
Re: Sweet...
I have now A/B'd 250ohm and 500 ohm resistors instead of a choke. The 500 ohm responds more quickly and the 250 slower, i.e. with increased sag. It will be interesting to try lower and see where the optimum point is. I preferred the 250.
Re: Sweet...
Thanks groovtubin, Thanks dogears.
I recall seeing a chassis shot of a dumble many years ago with a 10watt sandstone resistor near the P.T. ( didn't know what it was for), which leads to my next question.
To make this switchable (choke/resistor) what size switch is required?
Is it safe to use a 120v-6amp(240v-3amp) ect.? Are switches subject to Ohms law?
Re: Sweet...
Not to contradict you, but this does not make sense to me. Logically the higher resistance would lead to more sag. Are you SURE about this?Robert wrote:I have now A/B'd 250ohm and 500 ohm resistors instead of a choke. The 500 ohm responds more quickly and the 250 slower, i.e. with increased sag.
groovtubin
Re: Sweet...
dogears wrote:Jim,
Re: Sweet...
Agree with Pedro. Big ohm = more sag
mlp-mx6 wrote:Not to contradict you, but this does not make sense to me. Logically the higher resistance would lead to more sag. Are you SURE about this?Robert wrote:I have now A/B'd 250ohm and 500 ohm resistors instead of a choke. The 500 ohm responds more quickly and the 250 slower, i.e. with increased sag.
Re: Sweet...
That's me... LOL!
groovtubin wrote:Ah yeah you are right dogears, i`ve tried it alot of ways, just pefered that to the larger values. I was looking for just a HINT of sag. As with all this stuff, there really is no wrong or right, just what feels good to YOU!! LOL!!dogears wrote:Jim,
peace, jim ah, i know who you are now! LOL! Great ta hear from you!
