Thanks to all! You are a great bunch of guys.
Stephen
You nailed it! Leaky 5uF, I removed it and and issue was no longer there. I then went on to replace it and boom, amp is fine now! I really appreciate the help.
Hi Bombacaototal, did you try putting a .01uF cap across the return pot (pin1 to pin3)? That definitely suppresses the hum in my circuit which is similar to yours. A .1uF cap kills the hum completely but unfortunately it kills the reverb effect along with it, so the advice to go as small with this cap as possible. I'm starting to believe the hum originates in the power filtering feeding the reverb transformer and I am assuming you have the same (or at least a very similar) filtering scheme when your B+ for the transformer is marked '2A'. That would take the B+ from the screens node. Like mine. There isn't a whole of filtering at that point. However, I got the hum even without the tank hooked up so if my filtering mod makes any effect it could be because of the ground potential between the transformer and the return tube grid stopper (220k for V2B in yours, 150k for V4b in mine) which share the same ground point (J9 - the grounded OUT lug for the RVB cricuit). It would only take a very small amount of noise in the signal hitting the grid of the input side of the return tube for it to be amplified and then sent on to the Return pot...Bombacaototal wrote: ↑Wed May 11, 2022 6:27 am Today I wired the coupling cap of the send triode straight into the return pot. I basically removed the reverb send input lead, and took the return lead and placed there. No issues. With this test I am assured that the supply is fine (as send and return share the same anode), the reverb return pot is fine, as is the mixer circuit.
I also replaced the reverb pan cables just to be sure and no difference. I will start from the input of the driver tube and go all the way to the return pot and see if I have any luck, as the issue is for sure between driver and return pot.
EDIT: ok, back to the beginning, grounded the 220K of the reverb return (PIN7) and the issue is still here. There is so little circuit left and I already replaced the plates, coupling cap and the bypass cap. Also confirmed the return pot is not the issue . Will now replace the bypass resistor
EDIT 2: replaced the resistor, no luck. Only the socket left
Thank you. And forgive, I thought I detected a hum in the first recordings you posted. A ground loop? It's possible. For instance, MrD didn't isolate the jacks for the reverb in and out - which I followed - and that would create a loop with the pan installed. I'm thinking another simple thing I might try is to take the ground lead from the reverb transformer and move it over to the ground used by the screens (GND4) if I remember correctly.Bombacaototal wrote: ↑Wed May 11, 2022 10:31 am Hi Stephen, thanks for the input but I actually have no hum. My issue is different if you check the recordings. And sorry for hijacking your thread. I have replaced the pot and issue is still here. I noticed that if I remove the RCA return cable there is no issue. But if I ground the output of the RCA return the issue is still here. So odd!
Are you sure your issue is not a ground loop? I found that the grounding of the reverb driver supply sometimes needs to be separated. You can try at an independent point like the one of the power tubes ground or with the power supply. I had success with these two in different amps
I also had another amp I had to amend the reverb pan ground from input to output and that worked. Another one to try
Is the RCA coax grounded on both sides? In case of a ground loop caused between the coax shield and pin 7 ground.Bombacaototal wrote: ↑Wed May 11, 2022 2:23 pm I would definitely isolate the RCA jacks. Give it a try and let us know.
This is where I am at on mine: from the RCA return, I have a coax cable going to PIN7 of recovery stage and If I ground PIN 7 the issue is here. But if I remove the coax and ground PIN7 there is no issue. So strange! Also noticed that if I remove the RCA return cable (from the pan) the issue is not here too. I am so lost, such a difficult battle this time
