Too high voltage? (Solved)
Re: Too high voltage?
Voltage going in 14v in ac is no problem.
Can you measure the voltage at the voltage regulator:
Pin1: ?v in dc
Pin3: ?v in dc
Pin1: ?v in dc
Pin3: ?v in dc
- norburybrook
the transformer should be going to the rectifier/filter board then to the regulator.
what have you got coming out of the board to the regulator?
the regulator can take up to 30 vdc IIRC.
M
Pin1: 83mv in dc
Pin3: -0.001 mv in dc
I am using this board configuration? V reg output to pin 3 and V reg input to 1? Might it be the other way round?norburybrook wrote: ↑Thu Jun 27, 2019 2:10 pmthe transformer should be going to the rectifier/filter board then to the regulator.
M
Desolder the wires that are on pin 1 and pin3 from the voltage regulator; what is the voltage on the top right electrolytic that is on the relay filter board after desoldering and amp stby?
And now measure the ac in points on the same board in v ac.
That is 14.4v ac.
I have changed the diodes, there are some 7vac going across them, if that means anything.
I have two 1000uf electrolytes, but they ate only 16v. Would they be ok for testing?
I am attaching two pics of the board, if someone sees something I am missing?
The electrolytics on your pic says 1000uF/35v , leave them alone.Oddvar R wrote: ↑Thu Jun 27, 2019 4:36 pm That is 14.4v ac.
So after changing the diodes, how much voltage(in dc) is between the right top electrolytic and earth?
No change, it's the same.
- norburybrook
are the -ve, bottom of your caps tied together, to ground?
M
M
Yes they are, I have gone over the board many times, so I am blind maybe...
I don't know if this means anything, but the 84 mV's seem to pop up later?
I wonder if the wire from the top right positive side of the cap is going straight to the V reg pin 1? It seems like it's connected to the diodes, but is it?
