Moderators: pompeiisneaks , Colossal
erwin_ve
Posts: 1792 Joined: Fri Jan 25, 2008 8:06 am
Post
by erwin_ve » Thu Apr 18, 2019 4:21 pm
amplifiednation wrote: ↑ Thu Apr 18, 2019 10:21 am
Put the jacks and transformer under the preamp board on the chassis belly.
Thanks Taylor. Jacks out of the noise areas.
I dont have a transformer for the reverb because it is a transistor driven reverb.
Attached the schematic for reference:
erwin_ve
Post
by erwin_ve » Fri Apr 26, 2019 8:18 pm
The stand offs finally arrived, my supplier had them in backorder.
Did the final drillings for reverb in and out jacks.
Little progress:
erwin_ve
Post
by erwin_ve » Sat May 04, 2019 7:38 pm
Made some good progress. This build is more complicated and time consuming but also a lot of fun.
erwin_ve
Post
by erwin_ve » Mon May 06, 2019 1:27 pm
Only Signal board, Ps, heater and mains to do.
erwin_ve
Post
by erwin_ve » Tue May 07, 2019 1:37 pm
Signal en ps boards done. Off to heater wiring.
norburybrook
Posts: 3290 Joined: Mon Jan 06, 2014 12:47 am
Post
by norburybrook » Tue May 07, 2019 2:23 pm
erwin_ve wrote: ↑ Tue May 07, 2019 1:37 pm
my favorite
Looks great
M
erwin_ve
Post
by erwin_ve » Tue May 07, 2019 3:21 pm
norburybrook wrote: ↑ Tue May 07, 2019 2:23 pm
my favorite
Looks great
M
Thnx!
Lets see if I can solder tghe heatrs without touching other wires.
norburybrook
Post
by norburybrook » Tue May 07, 2019 3:37 pm
erwin_ve wrote: ↑ Tue May 07, 2019 3:21 pm
my favorite
Looks great
M
Thnx!
LOL..exactly.....
M
erwin_ve
Post
by erwin_ve » Tue May 07, 2019 5:35 pm
I've got this PT: what do I do with the Orange wire that is connected to the core?
pompeiisneaks
Site Admin
Posts: 4244 Joined: Sat Jan 14, 2017 4:36 pm
Post
by pompeiisneaks » Tue May 07, 2019 6:13 pm
Thats the faraday shield, you can ground it to get extra noise rejection.
~Phil
tUber Nerd!
erwin_ve
Post
by erwin_ve » Tue May 07, 2019 7:05 pm
pompeiisneaks wrote: ↑ Tue May 07, 2019 6:13 pm
~Phil
Thanks Phil, that makes sense!
erwin_ve
Post
by erwin_ve » Wed May 08, 2019 1:45 pm
Finished the electronics. Next is measuring and double check before startup.
erwin_ve
Post
by erwin_ve » Wed May 08, 2019 7:04 pm
It's alive!
Sound, drive, FET, PAB loop and reverb is working.
Little video; phasing is the low quality recording, but you get the idea.
pompeiisneaks
Site Admin
Post
by pompeiisneaks » Wed May 08, 2019 7:15 pm
Excellent! I edited your post to fix the 'youtube' linking. It's a bit odd but you just have to use the part after the end of the url, the unique string of characters and nubmers only.
Youtube links come in like 50 million variants, and rather than trying to support them all, this particular just wants you to use the unique part of the video itself.
Sounds like the phone may have done some AGC on on the levels, it had some kind of 'ducking' and compression if I heard right, but otherwise it sounds great! (my guess is that's the phone audio not the amp)
~Phil
tUber Nerd!
norburybrook
Post
by norburybrook » Wed May 08, 2019 7:35 pm
Erwin,
That's great
that sounds like the perfect amp for me
I would love an ODS with built in reverb and a built in loop
I have a reverb tank from a Deuce sat here
not sure I could re model one of my current amps though.
Do you have any more boards?
M
