erwin_ve wrote: ↑Fri Sep 21, 2018 10:30 am
1. Screen current isnt big, a few mA per tube. Bias differences can have bigger impact on voltages upstream. Using other tubes than original is gonna require a recalculation with the specs of the tube and might result in using a other transformer with different voltages/ different bias circuit.
2.bigger cap on the last node isnt just about cuttoff frequencies. It's also about feel, bouncier attack, more empasis on low end. Since english isnt my first language this is the hard to describe.
The way to experiment with this is to put a 22uF on the last node. Play with it and than tack another 22uF on top of the last one. Play with it. My findings are that it doesn't impact the tone but impacts the feel.
1. Many thanks Erwin. I am talking about the PSU dropping string resistors. Yes, I was taking into account the different transformers in the example cases of 6V6 or KT66. In the case of my amp I am doing a 2x6V6 with Deluxe reverb PT and Vibroverb OT with 2x JJ 6V6, and unmatching the impedance of the OT (original primary of 4K) to get it up to 8K. I will try to calculate what would be the equivalent dropping resistor (JJ 6V6 data sheet attached)
435 volts on the PT plates with JJ6V6 (max is shown as 450V)
The preamp valves will consume around 6 x 1mA = 6mA
The 6V6s are rated for 14 watts maximum, so they will probably be biased around 0.7 x 14W = 9.8W.
Raw DC supply voltage is 435V then they will each consume about 14W / 435V = 32mA, or 64mA for the pair.
I am confused with data sheet. Is screen-to-anode current ratio of 4.5? If so so we can expect the screen currents to amount to 64 / 4.5 = 14mA for the pair.
The total for the whole amp is therefore 6 + 64 + 14 = 84mA.
5% ripple voltage then this would mean 2x220×0.05 = 22Vpp.
C = I / (2 f Vripple) = 0.15 / (2 × 110 × 22) = 3.1uF.
6mA × 2.2k (PI) = 13V and dissipate 0.006^2 × 2000 = 0.79 watts.
So.....what do I do next?
2. That is great feedback. I am indeed curious to experiment with this. Do you find it stiffer/bouncier with the larger cap (ie 47uF)?
