erwin_ve wrote: ↑Sat Mar 17, 2018 12:05 pm
modman wrote: ↑Wed Mar 14, 2018 10:40 pm
Found it: I think it's a cap and then a resistor to ground, hence a high pass filter:
What am i missing?
NO it's a low pass filter.
We are trying to give user experiences to Pompeii. He's got the balls to show every move he makes on YouTube, which I think is a modern kind of heroism. So let's not pollute this topic with misunderstandings.
I am not an electronics engineer. I just learned this stuff off the interwebz. I am not ashamed to say that, schools are dead, I learned to repair my toaster, pave my patio, and a lot more too. So I'm also begging to be corrected.
If the signal goes through a capacitor and then through a resistor, it will create a
high pass filter. It will cut out part of the signal on the bass side of the spectrum. Check the wiki link for the formula to calculate which frequencies will be affected. Instead of messing with that formula you can just plug your values in this calculator:
http://www.trance-cat.com/electrical-ci ... ulator.php
The graphs accompanying it shows that all with a 250pF and 1k5 it cuts anything below 424Hz. With 270pF, anything below 392Hz.
If you know your guitar low E string is 82Hz, it's clear we are affecting the guitar signal. As this part of the circuit is the distortion, this matters even more to the 'sound' of the distortion.
Putting a 500pF in there will make a substantial difference. Then we are doubling the value... But really saying 20pF more or less will make a difference... in distortion circuit maybe yes, but as I said, you need to have high precision capacitors and be able to measure them accurately. It's hard measuring, I think Phil wondered about this in one of his videos, because the capacitance of the leads need to be taken into account to measure values that low really accurately.
This is also a non-inverting feedback loop... it feeds signal back through the cathode. But I might be wrong...
pompeiisneaks wrote: ↑Sat Mar 17, 2018 4:16 pm
I appreciate everyone's help here. I also was very happy that Charlie Wilson made it to the last livestream and was a great contributor to the discussion. I would be happy if any of you other geniuses would come along and forward the discussion and catch my SNAFU's
Phil, don't mean to hijack the thread, discussion is still on topic of the relevance of that cap beyond mere hearsay. I do think your a hero for what you are doing with your build, because despite a lot of mp3 demoes, there is in my perhaps too critical mind, too much doubt about the documentation on the Dumbles to start a build myself. I think anybody on this forum would be dying to see anybody just do an iPhone video display of the amp they've built. Inside and out. Run over the problems they've encountered and how they solved it. The biggest plug for this forum is still Fuchs mentioning it in his interview... that's the only reason I came here. That made me believe there is info here, but it really seems to be scattered.
what's a snufa?
