Dumbleland for sale
jelle
Re: Dumbleland for sale
Post by jelle »
Looks to be SVT transformers in this 300SL. Heyboer makes repros and I have seen those being offered at Fliptops and Mojotone.
I will do a 400W version at some point with vintage 400PS iron. Have fun!! Jelle
$300K for Greenie? :shock:
talbany
Post by talbany »
Structo wrote:$300K for Greenie? :shock:
That's nothing..I know Jimmy Page has had an offer of 1 mil for his 59 and turned it down.. :lol:
LeftyStrat
Post by LeftyStrat »
In the link I posted, apparently the new owner has been offered 1.3 million for Greenie and turned it down.
renshen1957
Post by renshen1957 »
LeftyStrat wrote:I agree Tony. KOC in TUT 3 talks about why a 100 watt Marshall sounds different than a 50 watt, but he attributes it to the difference between 2 tubes and 4 tubes, but I think there is more to it that that. I think the bass reproduction is going always be better with a high wattage amp, regardless of the volume.
Here's a 600 watt monster :shock:
http://ken-gilbert.com/the-big-ass-guitar-amplifier
Hi,
KOC goes into the difference in detail in TUT 3, (NFB resistor, PSUP Caps, etc). The transconductance of two tubes opposed four tubes (two parallel tubes as a composite tube) was expanded on in TUT 4, the GMX chapter using a single tube for tone and MOSFETS to supply either the tonal changes (of the additional tubes) or the extra power. I remember prior TUT 4 released KOC talked on this in several online forums. I wasn't into Randall bass amps but wondered on the connection when I heard of the 12ax7 tubes (for tone in the power amp) being pushed by solid state.
KOC's point of the chapter was how to get the tone of a higher power amp by using 4 tubes, a switchable NFB, etc, and being able to pull two of the tubes to get the "50W" sound.
As to better bass in a higher Watt power amp, Marshall uses undersized (compared to Hi-Fi) OT in the lower power 50W (read as 35 Watt) amps. Substitute a larger (full bandwidth) transformer such as a Hammond or an Edcor USA, or a Toroidal OT, and bass increases. The "Grandma's Chocolate Amp"and commented on by the Tone-Lizard.com was a 50 watt amp by Marshall that had a larger than normal OT.
I am of the opinion that the power supply Caps value make for the difference, too.
Best regards,
Steve
LeftyStrat
Thanks Steve. I need to pick up TUT4. The GMX circuit is certainly intriguing.
