Your build looks great! Interested to hear your report on how it sounds.
Raoul Duke wrote: ↑Fri Mar 01, 2024 3:48 pm
Here’s a random new guy question:
Given the space and alignment issues I’m experiencing with this build, is it a bad idea to put the V1 and 2 terminal strips up on washers - allowing the plate leads to pass underneath - thus providing more separation and shortening them by 33-66%?
Anybody ever done this and regretted it or know of why it might not work?
Thanks in advance!
I've found that you can also bend the chassis lug 180 degrees before you install the terminal strip and it will provide enough lift to slip a wire under.
1. Expecting to fire this up later today - should I start with the limiter even though I’ve already tested the power amp?
2. Don’t have my foot switch ready yet, so does the amp switch from clean to OD when it’s on “manual”?
3. Follow-up on the tube question: any opinions?
Thanks in advance! Going to try to disappear for a little while and get that last connection done. The house is quiet right now - but that could change any second, lol.
Raoul Duke wrote: ↑Sat Mar 02, 2024 6:13 pm
I would, just in case something got screwed up.
2. Don’t have my foot switch ready yet, so does the amp switch from clean to OD when it’s on pedal?
When you move the switch to manual you should get OD. I guess you didn't check the relay operation earlier?
You could put them in and power up with your limiter, and watch for any behavior that differs from your other set. If you can get them biased at full line voltage maybe they're ok, but a sound check would maybe say otherwise. It just depends on if and how much damage might have been done.
If you scrap them, I'd much rather get bias probe kit(s) from Hoffman than mess with salvaging the bases.
Raoul Duke wrote: ↑Sat Mar 02, 2024 6:13 pmThe house is quiet right now - but that could change any second, lol.
The test-as-you-go approach has served you well, and I can recall only one mistake that was caught this time around.
Ok, thought that confirmed something - but wasn’t certain.
Did the limiter then full power test. Bulb flashes all good.
- volume, treble, bass, and mid controls don’t work - switches don’t seem to work
- can’t get any OD
- poked around a little and found V1 terminal strip and plate leads are microphonic(?)
- FET is super weak, barely audible through speaker
- “thud” when switching operate to standby
Those voltages look good for the DC op point. Check cathode voltages on V1 and V2 (pins 3 and 8) just to confirm they are conducting current, and check the voltages at the top and bottom of the FET drain resistor.
As for no sound, seems like there is a break or unintentional grounding in the signal path somewhere.
As for the break or grounding - where’s the best place to start and check? Am I looking for continuity from cap to cap on the main board from left to right or something similar?
One other thing is when I turn the master up, I get a dull hum that increases in volume as the MV is turned up. Sounds like when you have your finger on the 1/4” plug if you unplug the guitar with everything on.
V1 & V2 cathodes look reasonable, FET is biased a bit hot. You said the FET input gets some sound, but nothing from the normal input? Maybe start by checking the input jack wiring over carefully. You could try putting signal into the input and tracing through the signal path to see where it stops using your DMM, measuring AC volts or frequency.
I was thinking of lifting the main board and taking a peak underneath. If I undo everything on the pot side I can peel it backwards without disrupting tube sockets I think?
